Possible issue with the remote controller unit - main board or sub assemblies. The intermittent behavior seems to indicate that the board is erratic to detect at the same time the individual locks work at times.
So make sure all the connectors to the door and to the main board controller are tight. You can remove the main unit and check for any loose connections or clogging, specially water in all the door units or in main unit. If so dry and test.
Otherwise the main unit is a suspect.
