Question about Cycling
What is the maximum weight this bike can take,eg[weight of person]
  • David Dunn
    David Dunn Mar 12, 2011
    No bike specified in the question. Check the manufacturer's website. If it has any stupid-light parts like wheels or cranks it's not made for Clydesdales (generic term for >200 lbs). Smaller bikes are madefor light people.
    Sergeant:
    Champion:
  • 263 Answers
120
Posted on Mar 12, 2011
What is the proper tire pressure for P235/70R15 on Chevy Blazer
32-35 psi cold or hot air pressure usually has a 2-3 lbs difference...See Owners manuel or tire man. recommendations..
Feb 24, 2015 | 2001 Chevrolet Chevrolet Blazer
Owners manual what is the weight limit
There is no maximum passenger weight capacity listed in the owners manual for my Boulevard S-50, and no maximum passenger weight capacity for the Marauder 800 (which is almost exactly the same bike) listed anywhere that I can find on the internet. The front and rear springs are adjustable for passenger weight, but I would suggest the maximum weight is limited by the rear tire capacity stamped on the sidewall and what weight you feel comfortable handling. Don't forget to include the weight of the motorcycle (about 456 pounds) and the weight of the gasoline (about 6.0 pounds per gallon).
Sep 08, 2014 | 2004 Suzuki Marauder 800
How much combined weight is allowed on the 1999 800 suzuki maurder
As I answered to the same question posted by G. Moore:
"There is no maximum passenger weight capacity listed in the owners manual for my Boulevard S-50, and no maximum passenger weight capacity for the Marauder 800 (which is almost exactly the same bike) listed anywhere that I can find on the internet. The front and rear springs are adjustable for passenger weight, but I would suggest the maximum weight is limited by the rear tire capacity stamped on the sidewall and what weight you feel comfortable handling. Don't forget to include the weight of the motorcycle (about 456 pounds) and the weight of the gasoline (about 6.0 pounds per gallon)."
How would change the tires yourself at home on the buell because the exahst is on the bottom of the bike??
The stock muffler is designed to support the weight of the bike, you can use various jacks to lift the bike from the muffler, but I personally prefer to use swingarm and tree stands as they are more stable. Americansportbike.com sells some nice PitBull brand stands that work great.
Jul 06, 2011 | 2003 Buell Lightning XB9S
My moto did not attend his maximum speed
there alot of factors involved, gearing, wind resistance, weight of rider.revlimiter..you may not get the max speed out of bike as stated bu manufacture & i may be unsafe to do so..
Mar 30, 2011 | Yamaha Ybr 125 Motorcycles
Need to know the maximum load weight capabilities of this bike for travel loads
Rider, passenger, accessories and cargo should not exceed 160kg/352lbs. Cargo weight should not exceed 30lbs. That's from the owners manual, see same info and more at link below.
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/CB250-1992.pdf
Cheers.
Apr 22, 2010 | 1992 Honda CB 250 Nighthawk
What is the maximum weight load?
There is no real correct "max" weight. The bikes suspension travel will produce limits in handling and top speed as the weight increases, It should be able to carry to 2 adults with ease, say 180kg, If you are carrying big loads, then additional tyre pressure would be advisable. Upgrades in rear spring rates would be advisable also if you intend to do touring with heavy loads. You can get a full service manual here for the correct pressures to run and suspension adjustments you can make for high loads. Cheers
regards robotek
Jan 17, 2010 | 1994 Honda VT 600 C Shadow
Towing capacity for an Isuzu I370 pickup
As listed in the owners manual.
Weight of the Trailer
How heavy can a trailer safely be?
It depends on how you plan to use your rig. For
example, speed, altitude, road grades, outside
temperature and how much your vehicle is used to
pull a trailer are all important. It can also depend
on any special equipment that you have on
your vehicle, and the amount of tongue weight the
vehicle can carry. See “Weight of the Trailer
Tongue” later in this section for more information.
Maximum trailer weight is calculated assuming
only the driver is in the tow vehicle and it has all
the required trailering equipment. The weight
of additional optional equipment, passengers and
cargo in the tow vehicle must be subtracted
from the maximum trailer weight.
The following charts show how much your trailer
can weigh, based upon your vehicle model
and options.
2WD Extended Cab Axle Ratio Maximum Trailer Weight GCWR*
Automatic Transmission,
2.9 L Engine 3.73 3,100 lbs (1 406 kg) 7,000 lbs (3 175 kg)
Manual Transmission,
2.9L Engine 3.73 2,100 lbs (952 kg) 6,000 lbs (2 721 kg)
4WD Crew Cab Axle Ratio Maximum Trailer Weight GCWR*
3.7L Engine 3.73 4,000 lbs (1 814 kg) 9,000 lbs (4 082 kg)
*The Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded
vehicle and trailer including any passengers, cargo, equipment and conversions. The GCWR for your
vehicle should not be exceeded.
Aug 26, 2009 | 2006 Isuzu I 370
Towing capacity
Directly from the Toyota Spec Book:
Maximum trailer weight: 1,500 lbs
Maximum tongue weight: 150 lbs
Hope this helps; and, thanks for choosing FixYa!
Oct 25, 2008 | 1997 Toyota RAV4
Cycling Logo
43 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
