Question about Roper RS22AQXKQ Side by Side Refrigerator
I have a double door Roper refrigerator Mod# RS22AQXGWO3 ser# SL2125782 Type 22SSA Does the unit have a filter for water and ice make.
SOURCE: icemaker does not work
Remove the white cover in front of the ice maker by pulling straight toward you. There is a white gear made of plastic that might broke off, you probably have to replace motor module assembly. My Roper ice maker quit making ice and found the problem, I'm shopping for cheaper part replacement which is being secured by 3 screws.
Posted on Oct 29, 2007
Cyril J
  • 45 Answers
SOURCE: looking for refrigerator use and
i do not think that is a good model serial number. at least not the format that whirlpool has used in several years or in the u.s.a.
the model serial numbers should be on a tag easily located with out moving unit.
unless this is a vendared product with a Whirlpool name on it (usually a dorm frig or the like)
Posted on May 16, 2008
bobicehouse
  • 1524 Answers
SOURCE: On a Roper ice maker, ice is not making but
In the back of the ice maker on top
Posted on Apr 27, 2009
pride applia
  • 232 Answers
SOURCE: No Water
is there stuff freezing in the veggy drawers water storage is behind it, if not find water valve test for power to it wile button is pushed the one with the larger line is the one your testing if you got power replace it
Posted on Jul 02, 2009
woodchuck789
  • 4070 Answers
SOURCE: my roper side by side ice maker does not work
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
See if the ice maker starts working when it dumps the ice.
Posted on Sep 28, 2009
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Water is dripping out the bottom when you open the frezer door and when you go to get water
first thing to check would be the bottom and back of the inside of the freezer and see if you have any ice build up if you did this would be a defrost issue you can read more about this if you do have ice by clicking this link http://applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm another thing you can check is the door seals if you have a rip tear or pinch in the door seals this causes condensation to build up or if you also have water that is on the door there is a line that goes through the bottom of the hinge that brings water to the water dispensor you basicly need to find out where the water comes from remove the rear panel inside the freezer if you dont see ice just to double check there is a small drain hole under the condensor that sometimes also freezes up with ice in some units so look further into where the water is coming from and message me back if you have any further questions and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Mar 14, 2011 | Roper RS25AEXLQ Side by Side Refrigerator
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Hi, In my refrigrator there is no water and ice coming.and i dont find where is the fiter.my refrigrator type is 2255a mod # ed2choxkb07 ser,# issu4235315.thanks
Since you did not provide a model number this is the best guess. On 25 Cu Ft and above models no matter the manufacturer most of the filters are in the left portion of the grille at floor level. You turn the tab and the filter pops free. If yours is not in this are just respond here with a model number and I will help you.
Kelly
Oct 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in door works but ice maker quit .its a roper side by side mod#rs25aqxfnoo ser#sg1235753
That ice box uses a dual solenoid dual mechanical valve and operates the water on one side and ice maker on the other. The solenoid for the icemaker (which has a smaller water line) might be open or the mechanicals inside may be fouled with sand and sediment or lime deposits. If that checks out then the thing that powers that water valve is the ice maker itsel. So if your water valve is good then your ice maker is bad most likely. I have a page which shows repair photos and manual: HERE
Feb 14, 2010 | Refrigerators
No water going into ice maker on our roper side by side refrig
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jan 05, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
You can get water from door but no water going into icemaker roper
the ice maker give 120V for short time to water valve when the time come for new batch of ice. if the valve not getting it your ice make unit need to be replace.
Dec 31, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Water filter replacement?
You do have a filter on the bottom kick plate. It looks like a round cap and it's the same color as your refrigerator. Give us a call and we'll be happy to send the correct filter out to you. Hope this helps and we look forward to hearing from you soon.
Oct 06, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
26 side by side with ice maker doesn't work
The water control valve can get clogged or fail. Follow the line from the supply( did you check for filters there?) to the bottom of the fridge. The valve may be just like the one on a washing machine. It has a wire filter in it too. Test it for flow, unhook the pipe to the ice maker and see if water comes out of it when it is energised. I made a test energiser out of a power cord with the same connectors that the valve has.
Apr 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Roper RS22AQXKQ Side by Side Refrigerator Logo
108 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
