Question about Haier Dishwashers
I have a de longhi dw67s dishwasher that intermittently refuses to operate the wash pump. the machine just hums and the timer continues - no error codes or anything - thought it may have been the start capacitor, or the motor but both seem ok - other thought is the controller? any ideas?
5 Suggested Answers
SOURCE: Loud Whining/Humming noise while washing
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Posted on Mar 22, 2008
SOURCE: asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Posted on Feb 13, 2009
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Posted on Mar 30, 2009
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
KitchenAid fills and drains but won't wash
With a lot of such appliances, the pump motor runs one way to wash, reverse to pump out. Refusal to do this usually is a loose wire, poor connection in the timer, or a wire on wrong. Check the schematic carefully for that.
Nov 30, 2013 | KitchenAid 34 in. KUDP01FLSS Stainless...
My ignis adl 347 dishwasher will not empty its self i put it on a cycle it hums for a while then it starts bleeping continually and light flashes were you turn it off
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. The drain pump can be clogged and refuse to work as it hums. If so remove and clean the drain pump, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated.
Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Thank You for using fixya
Sep 21, 2011 | Dishwashers
Deloghi dw67s dishwasher, drain pump on continuously, showing E4 and no water in washer. What is used to detect the overflow?
Hello
There is a slight leak somewhere or the machine keeps overfilling causing the drain pan to activate via the flood switch.
remove all dish trays from washer, unscrew and remove lid off salt softener, almost and thoroughly remove as much excess water as you can, it could be the vacuum switch/water level float.. do the tip over again, and be sure you get it all,
replace all trays and softner lid and machine should work again.
Aug 09, 2011 | Dishwashers
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Delonghi dishwasher won't drain.
I have the same machine with the same error message but my machine has drained it self but will not continue the cycle?
Mar 09, 2008 | Dishwashers
Code de
de is 'door error'. I just fixed this with a new door catch/switch (called a door overlock). Theres a bi-metal strip in there that makes the contacts as well as keeping the door locked closed when its working and it looks like this was the culprit as I was able to open the door even when the machine was filling. The de was intermittant, if you continued to open and close the door it would start eventually - if it does this try changing the switch, cost about £30.
Feb 21, 2008 | LG WM-2277HW Front Load Washer
De Longhi E4 error
Basuda! Sorry! Cheaper to get another one than to fix!
Nov 06, 2007 | DeLonghi CF210 Portable Air Conditioner
Dishwashers Logo
Top Haier Dishwashers Experts
Renee Knafel-Bullock
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
