Question about Fuji instax mini 7S Film Camera
I tried taking a picture, but the film comes out blank. I tried again for 3 times, but the results is stil the same. What should I do? I only got this camera for less than 2 weeks :(
  • gitasum
    gitasum Jun 09, 2012
    that's also happen to mine. is it works just only check the shutter?
  • 38 Answers
Please check the shutter of your cam...even the cover nothing opened...
Posted on Mar 12, 2011
My polaroid camera won't eject the film. Are the cameras broken or is the battery dead?
When you take a picture of darkness, are you using flash or uprating the film ?
More seriously, as the film is thirteen years out of date, I seriously doubt if it is still viable. The chemicals within the film pack will have deteriorated over time, and it is my guess that they may well have leaked into the film pack's internal mechanism, thus preventing the photos being ejected. Try again with fresh film.
Jun 14, 2016 | Polaroid Cameras
Film not developing
I have the same problem as you. Pictures are in black and photo cartridges already wasted 3. Today I opened my camera and not a spring tea that is attached to the lever capture modes (sunny, noblado etc) was detached. Because I remember when the camera is turned on (pulling the lens) capture modes to move too. So every time you take a photo you must manually set the capture mode, and it stopped working. I hope it is resolved by attaching the spring. You already solved?
uma_t5 (a) hotmail.com
Jan 21, 2014 | FUJIFILM instax mini 7 Digital Camera
Why is my canon ae-1 only developing blank film
First thing I would do is sacrifice a roll of film. Load the film as you have been. Then with the back open and tension on the film (do not touch the film over the shutter, advance the film. It may be that you are putting the film on the takeup spool incorrectly. Watch how the film advances on the spool. If it is on the spool incorrectly it will disconnect then not advance. If that does not work it may be a errant takeup spool.
Jul 06, 2012 | Canon EOS-AE-1 35mm SLR Camera
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
Picture film comes out blank
Having gone over a month with no response, I assume this is no longer a problem.
May 29, 2010 | Nikon N75 35mm SLR Camera
Camera lens go in and out about 3 times, I cant take pictures.
1. Remove the battery and reinsert it after 30 seconds. 2. Try resetting the Camera. To reset, refer supplied Manual. 3. If stil not resolved, please get the device serviced.
Aug 06, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Loaded film blank
Chances are the film had quite a bit of curl to it (often a sign of old film) and it was not pulled over quite far enough during auto loading, or perhaps too far and it had too much slack that the take up reel never grabbed it to advance it thru. You're not the first one this has happened to as the auto load is not as reliable as the older style where you had to load the film leader through a slot in the take up reel.
Dec 19, 2008 | Nikon F65 35mm SLR Camera
2 rolls out of a 3-pack ruined.
I would suggest you buy an off-brand roll of 12 or 24 exposures. Run it through the camera taking snaps of anything -- but make sure you vary the lighting, ISO, shutter speed, aperture, etc. as you snap the pics. Don't worry too much about composition. This roll is a quick test, NOT for photos to keep.
Have the film developed and then follow-up with comments on the results. I'll gladly assist you further at that time.
Char1ieJ
Nov 11, 2008 | Nikon N65 35mm SLR Camera
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Fuji instax mini 7S Film Camera Logo
643 people viewed this question
Top Fuji Photography Experts
Jax Planet
Jax Planet
Are you a Fuji Photography Expert? Answer questions, earn points and help others
