Question about Eaton ARC FAULT CIRC BREAKER
Have three 20 amp Eaton Arc Fault Breakers Type BRAF and two have tripped and cannot reset. What is the solution? Do I need to replace?
  • 5,603 Answers
If you disconnect the load wires on the breaker and it will not reset, the breaker has a fatal flaw.
IF the breaker ONLY fails to reset with the load wires connected EITHER there is a wrong connection like servicing a shared neutral 3 wire cable from the breaker, or there is an electrical fault OR there is interference from a source that couples radio-like noise onto the wires to this.
Posted on Mar 12, 2011
Why are these breakers hot and constantly draw .35 amps from the ground bar?
When current is going through wiring and devices it normally operates warm. That is why most wire and devices such as breakers are rated at 70 degrees Celsius. In a panel, heat can be transferred through the buss bar they are connected to.
Breakers will trip for 2 reasons. Overload amperage and heat.
Oct 05, 2016 | Eaton ARC FAULT CIRC BREAKER
15amp Eaton Arc fault breaker type BRAF trips every day at same time. There are no high amp electrical things plugged in. What is causing this? should I have it replaced?
"Arc fault" breakers trip when an arc occurs, either in a receptacle or a light switch, for example. An arc can be caused by an old light switch, when turning it on. An arc can also occur when you unplug a chord while the device is still turned on or running.
Aug 25, 2013 | Eaton ARC FAULT CIRC BREAKER
I am familiar with AFCI breakers, but BRAF is new to me. What is BRAF?
BRAF is a heat dissapation specification. There are 3 kinds: 601, 602 and 603.. They range from low to high.
Aug 19, 2011 | Eaton ARC FAULT CIRC BREAKER
We have a new 12 room motel addition we are wiring. There are two bathrooms in which the arc-fault breakers are trippping. The loads are - two three lamp incandescant wall fixtures, and two GFCI...
Hi, I know it sounds simple but sometimes its the simplist things that get you. Check your earth, as it sounds as if this may be causing the problem.
Sep 28, 2010 | Eaton ARC FAULT CIRC BREAKER
Eaton afci breakers tripping out due to lightolier low voltage lighting. Lightolier and eaton both agree that it is a frequency problem but neither has a solution. Any help?
everytime I plug in my vacuum cleaner (Kenmore canister model) I trip the Eaton AFCI Braf breaker. Now it doesn't even work though I can flip the switch back to the on position
Jul 19, 2010 | Eaton ARC FAULT CIRC BREAKER
Eaton Arc Fault Breaker type BRAF tripped. I reset it but lights will not work. Ideas please?
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
Feb 19, 2010 | Eaton ARC FAULT CIRC BREAKER
Arc fault circ breakers are very warm
if its a 100 amp panel only 5- 20 amp breakers, if its a 200 amp panel 10- 20amp breakers
Dec 23, 2008 | Eaton ARC FAULT CIRC BREAKER
Arc fault circ breakers feel warm
If the breakers are 20 amp and the panel is rated at 100 amps, only 5 breakers. if the panel is 200 amp, only 10, 20 amp breakers and so on
Eaton ARC FAULT CIRC BREAKER Logo
771 people viewed this question
Top Eaton Electrical Supplies Experts
john h
T-Comtech Repairs
T-Comtech Repairs
Are you an Eaton Electrical Supply Expert? Answer questions, earn points and help others
