Question about Apple iPhone Smartphone
After i inserted my sim card, there is a note at the upper left corner NO SERVICE. pls help me
  • Apple Expert
  • 302 Answers
Do you have a factory unlocked iPhone?
If yes, try to toggle the airplane mode on and then off.
Or you can also reset network settings.
Check also the sim, it might have loosely placed..
Let me know if this works or not so I can give you other suggestions.
Posted on Mar 12, 2011
How to insert sim
sim card has cut edge on one corner.
this side goes in forward.
cut edge is always top left corner.
SIM logo is top of sim card,
Mar 27, 2017 | Cell Phones
How do i install sim on a kyocera c653 phone
Did you mean the Hydro-life C6530N phone? There is no C653 listed on the Kyocera USA web site. The following is copied from page 9 of the manual for the C6530N:
Insert the SIM Card
1. Insert your thumbnail or fingernail into
the slit and lift the battery cover.
2. Grasp the white pull-tab extending from
the battery pack and pull the battery out
of its compartment.
3. Use your fingernail to carefully pull out
the SIM card tray.
4. Place the SIM card into the tray, with
the gold contacts facing down and the
cut off corner on the top left. Insert the
SIM tray back into the SIM card slot and
push until it clicks into place.
Note: Make sure not to insert the SIM
tray in the opposite direction.
5. Insert the battery, contacts end first, and
gently press into place.
If the tiny type is too hard to read, you can view the manual with a PDF reader at http://www.kyoceramobile.com/hydro-life/Hydro_LIFE_User_Guide_T-Mobile_en.pdf
There is a different manual for the MetroPCS version of the phone, but the SIM card installation is the same.
Jan 03, 2015 | Kyocera Cell Phones
How do I put my sim card in my phone
hey,
all you have to do is remove the back, the little tab at the bottom. Pull out the batter and insert the SIM card in the middle slot. Insert the SIM card so the cut corner is facing top left. Follow the picture. Then re-insert the battery and backplate.
Mar 31, 2013 | T-Mobile My Touch Cell Phone
Why I don't have network signal on my nokia 6600?
If you are not getting any network from your phone it my be be due to:* sim card issues* network / outage issues* phone issues
SIM Card issues:1. turn off mobile phone2. remove battery3. remove SIM card and memory card4. clean the SIM card from any dirt or dust5. wait for 2 minutes then plug back battery6. insert memory card and SIM card properly7. turn on mobile phone8. check if you will be provided with a signal from the upper right corner of your phone's screen. if not, try a different SIM card.
Outage:1. call your service provider and confirm if there are outages in the area or outages from the BTS where your SIM card is registered.
Phone Issues:1. if the phone is open line, try to enter a different SIM card2. try to insert the SIM card into a different phone, check if it will be provided with a signal3. if the second phone still dont get any signal and your service provider stated that there is no outage that may affect signal issues from your phone, check it from them if your sim card is still active.4. last resort is asking for a SIM replacement with the same phone number
Dec 11, 2011 | Nokia 6600
Were do i put the sim card i have a nokia 6111
Hello fridge,
i have some tips on how to install sim card on your cellphone:
Install SIM card
1. Make sure that the cover of the connector
panel is closed.
2. Slide the phone open.
3. Open the SIM card compartment (1) on
the back of the slide
4. Slide the metal SIM card holder towards
the compartment lid to release it (2).
5. Open the SIM card holder.
6. Insert the SIM card in the holder as shown (cut corner at
the upper right).
7. Close the SIM card holder, and press it down slightly.
8. To lock the SIM card holder, slide it away from the
compartment lid (1).
9. Close the SIM card compartment (2).
hope this helps :D
Apr 24, 2011 | Nokia 6111 Cellular Phone
Hello pls help. my nokia 3100 wont turn on if i insert a sim card, but it will turn on if i didn insert a sim card. what is the problem? pls help
It is a software problem. Contact your nearby service center and they will fix the problem by updating your software.
Nov 03, 2010 | Nokia 3100
Screen says Please insert SIM card
A SIM card is a little chip, size of a thumb nail, used to identify yourself as a valid customer of a phone network. If you do not have one, you need to buy from a phone service provider first, your mobile does not allow you to make phone calls without one.
The SIM card must be installed in your phone, for the A767 you have to open the lid on the back, remove the battery and slide it into a slot in the upper left corner of the battery compartment. The contacts of the SIM should face down, the little triangular clipped off corner should be on the right, bottom side when you put it inside.
If you purchased a SIM before already, and installed it properly, it may got loose in its little hatch, e.g. by rough handling. Make sure the SIM card is properly in place (proper orientation and still all way in its slot).
The SIM card may also got dirty or liquid may have entered the phone case. In this case, remove the SIM, carefully clean it and the inside of your phone, reinstall and retry.
Oct 24, 2010 | Samsung Propel A767 Cell Phone
How do I remove the battery and put the sim card in my new nokia 2760 cell phone
These are steps from the Nokia 2760 manual found at :
http://nds1.nokia.com/phones/files/guides/Nokia_2760_UG_en.pdf
(pages. 12-13)
1. Press and slide the back cover toward the top of the
phone to remove the cover .
2. To remove the battery, lift it as shown
3. Carefully lift the SIM card holder from the finger grip
of the phone, and open the flip cover
4. Insert the SIM card, so that the bevelled corner is on
the upper left side and the gold-colored contact area
facing downward.Close the SIM card holder, and
press it to lock it into place
5. Insert the battery into the battery slot
6. Align the back cover with the back of the phone. Slide
and push it toward the bottom of the phone to lock it
Apr 14, 2009 | Nokia 2760 Cellular Phone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
