Question about Ingersoll Air Tools & Compressors
I have a 60 gallon ingersoll rand model#ir5e6va i need to find an owners manual that i can download and a diagram of the pump where is the model number on the pump i need a rebuild kit and cant find any info
  • 22 Answers
SOURCE: Where can I find the owner's manual for an IR Type 30 model 25T
IR has not made their owner's manuals available online. You have to contact your nearest dealer in order to get one. If you do get one, could you please consider uploading the manual to fixya.com to help other people who a looking for the same thing.
Posted on May 13, 2009
  • 76 Answers
SOURCE: Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
Posted on Jun 26, 2009
  • 98 Answers
SOURCE: i need to download a
call I.R and they will send you a manual for a small charge.
Posted on Jul 21, 2009
SOURCE: Ingersoll Rand SSR-EP75 owners manual, I need to
The pulley is held on by a compression type of coupling. Loosen all the screws in the coupling. Remove two screws and they should thread into two or more threaded holes in the coupling. These are holes that should be 180 degrees apart....they will be the only holes threaded. If all the other bolts in the circumference are loose you should be able to thread these two bolts into the coupling and the bolts actually "jack" the coupling apart. The coupling and fan should easily come off the front of the motor. The motor should be held on by 4 screws to the motor tower in front of your air/oil cooler.
Posted on Sep 04, 2009
Testimonial: "Although the information is way late, it is accurate information"
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
Ingersol rand 80 gal 5 hp manual
follow the link
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-877.pdf
Sep 07, 2014 | Ingersoll Rand SS5L5 Ir Electric...
Diagram of parts
you can download ingersoll rand tool manuals and parts lists from
www.irtechpubs.com
Jan 22, 2012 | Ingersoll Rand 1/2" Super Duty Air Impact...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
May 13, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Owners manual
Get on E-Bay and type in a company by the name of "Industrial_ Manuals". They're a real good source for air compressor manuals. John
Mar 23, 2009 | Ingersoll Rand Compressors 5-HP,...
Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Mar 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Air Tools & Compressors Logo
900 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
