Question about Kenmore Washing Machines
A friend of mine has a stackable washer and drier,that wont spin when it gets to the spin cycle.i manually put it in the spin cycle in each wash setting,nothing happens at all.nothing comes on ,nothing happens.
  • 31 Answers
Your motor is probably going out.
Posted on Mar 12, 2011
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
Jun 02, 2016 | GE Spacemaker Washer and Dryer Electric...
The water in my stackable washer and dryer wont drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Violent spin cycle on the Frigidare front-loading washer
I assume you bought it new, so on that basis, did you remove the transit packing materials inside the machine ?
Front loading washing machine normal design is for the drum assembly to be supported by two or more springs at the top, and two dampers at the bottom. This allows the drum to move in a controlled fashion and also minimises vibration, particularly during spinning.
When the machines are shipped from the factory, transit packaging is put inside the machine to ensure that any shocks to the machine during transit dont damage the springs or dampers. This must be removed before use otherwise you get pretty much the symptoms you describe.
The manual that cam with it will show you how to remove the transit packaging. In such a short time I suspect you wont have suffered any damage, but take the transit packaging out as soon as possible.
Nov 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Excessive spin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
Jul 20, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Sal De
fordexpert
Robert Rankin
