Monitor has small message box saying Out of Range when connected to my PC but works fine when connected to laptop lowered to 600 to 800 pixels and notheing changed
  • 302 Answers
It means that the maximum resolution of your monitor is 600 to 800 only. Anything that's higher than that will not display the screen. Although you can try setting it a bit higher because most of the monitors have a standard screen size of 1024 x 768 but if it's a VGA monitor, chances are the max size is already 600 x 800
Posted on Mar 12, 2011
  • 27 Answers
Right click on the desktop go to properties (win xp ) go to the display tab. Right click on the image of the monitor and make sure attached is checked.
Dclcd monitor
Seems the screen resolution of your pc is high (higher than your monitor can support). You may lower the resoltion by connecting your pc to another monitor temporarily and changing settings then.
Nov 18, 2013 | Philips Computers & Internet
Olevia LT23HVX screen resolution
what kind of cable are you connecting with? If you are using a Composite or S-Video cable perhaps you may want to use the VGA cable instead and see if that corrects the issue.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
The monitor works when connected to my laptop but when I connect it to my desktop, I get a little message box that says Out Of Range?
Right Click on your desktop go to Properties (for xp) or Screen Resolution (win 7 and vista) lower the screen resolution. What the error means is that the resolution is too high and the monitor cant handle it.
Mar 12, 2011 | ViewSonic VG700b 17" LCD Monitor
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Connection hook up problem
Set the resolution lower.
It is telling you that the resolution you want is beyond its normal operating range.
just drop it to lets say 800 x 600
Then bump it up one resolution at a time until you get the message again, then drop it back one.
Running monitors above the acceptable range can drastically shorten their lifespan.
With lcd monitors you are much better using the DVI cable if yout video card supports it.
Sep 07, 2009 | Computers & Internet
Out of range
Try lowering your refresh rate from 85hz (or higher) to a lower value around 70hz.
This usually will correct out of range issues.
Jan 28, 2008 | Liquid Video L17LCD2 17" Flat Panel LCD...
Out of range
Out off range means the resolution coming out of your laptop is too high. Remember it's the res. of your second monitor you'll want to change. I'm thinking it'll be 1024x768 max, but may even by lower. Hope this helps.
Jan 22, 2008 | Bush WS6671 28" TV
Flickering pixels
plug it in all the way thats how i did it
Oct 30, 2007 | NEC-Mitsubishi Nec Display Solutions...
Range Warning
first, 68.5 khz -85hz means horizontal raster frequency of source signal is at 68.5 kilohertz and repeats vertically at 85 hertz. (hertz means "cycles per second). the sony monitor cannot "read" the signal being sent from the pc. change the screen resolution to a lower number like 75 or 70 hertz vertical.
Jun 05, 2007 | Sony SDM-HS95 19" TFT screen silver LCD...
Computers & Internet Logo
David Payne
David Payne
