I have had this machine for 4 years now in the last 12 months or so i have to clean out the drain filter at least once every 2 weeks if i dont it wont spin i have worked out how to fix that, back of pump out, clean it out back togeather. Is there something wrong with the lint fliter system because there is to much stuff in the drain filter thing help or its out the door
    Brigadier General:
  • 6,277 Answers
NO! There is nothing wrong with the filter- it is doing the job that it is meant to do.
The machine will not finish cycles knowing that there is water still in the machine; that's what it is designed to do- stop.
The cause of the filter becoming blocked frequently is that the items being washed are poducing the lint/fluff/and whatever else ;-0)
Make sure you are cleaning and clearing the filter completely each time, the pipe which goes to the drain motor AND that there is nothing restricting the impeller turning.
Please read my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 12, 2011
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Intermittant 0E error
I believe the OE error is generated if it takes too long for the washing machine to drain. If the drain is blocked or the pump is is not functioning well, the error will show up intermittently. I believe we experienced a similar error a couple of years back. After verifying the drain was clear, I replaced the drain motor, I believe the washing machine was about 5 years old at that time.
Feb 28, 2013 | LG WM-2277HW Front Load Washer
Im on my 2nd big buddy and both of them the fan has gone out, the first on went in a week, and this one last a couple of months.
fans
1. oil the bearings,sae 30 or wd40 for places you cant get into.
dont take fan motor apart unelse you realy have to.
dont let your fan motor bearings get worn egg shaped from lack of oil.
2. make sure fan blades not hitting or scraping fan housing and fan blades are securely fastened to fan motor shaft.
3.mr heater fan motor is 12 volts DC , so it may have a segmated comutator and brushes.
I dont know because i have not yet needed to take my mr heater
fan motor apart but i have worked on hundereds of ac fan motors
in the past 65 years.
4. keep fan motors from getting wet. they hate water.
5. keep fans clean, they dont like foriegn materials.
Your specific problem: first fan 2 weeks,second fan 2 months.
how much you use them, are you wearing the brushes down?
Getting fan motor wet? foreign material getting pulled into fan or fan motor? off/on switch work ok. batterys good,battery contacts ok? fan transformer 110 vac to 12 vdc good? fan bearings oiled?
need more info to diagnose properly.
all of the above needs to be checked out to tell whats happened.
fan & fan motor needs to be inspected.
Feb 21, 2011 | Mr. Heater Big Buddy Heater
What kind of maintenance should i do to my 1989 cbr 600 f to keep it in tip top running condition
  • Change gearbox oil every 3000 miles. Change oil filter every 6000 miles. Use 10w40 motor oil. NEVER use synthetic lubricants as they can mess up the clutch.
  • Oil the chain every two weeks. Lube the control cables every oil filter change.
  • Keep the gas tank full in the cold months. This lessens internal tank rusting due to condensation in the tank. Drain the carbs when the bike will sit over the winter unless you plan on starting the bike every two weeks and letting it run for 15 minutes each time.
  • Be sure the gas valve is turned off when the bike is not in use.
  • Get a 2 amp trickle charger and charge the battery once a week for 4 hours in the winter. Be sure to keep enough water in the battery to cover the top of the plates in each cell. Know that batteries only last two years or so.
  • Check the chain tension once a month during the summer riding season.
  • Please rate my answer. Thanks.
Sep 11, 2010 | 1989 Honda CBR 600 F Hurricane
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Year lo 1 time month lo 2 times weekly 4 times rojulo 6 times vachedi enti ?
year lo 1 time(12 months: 1+2=3 odd)
month lo 2 times(1 week and 3 week these are odd numbers)
week lo 4 times(1 Sunday, 3 Tuesday, 5 Thursday, 7 sat day)
day lo 6 times( 1o clock, 3,5,7,9,11)
Jun 07, 2010 | Nokia Lands Phones
Bread Machine non-stick starting to peel off
Since your machine is only about 6 months old, it should still be covered under warranty. I'd contact the manufacturer. (Contact information should be in the instruction manual). The teflon coating is just a sprayed on coating. Once it starts to peel, it's not safe to use them. It becomes hazardous (possibly eating it in the bread).
It sounds like you've taken care of the pan as it's supposed to be. If this was an older machine, I'd suggest ordering a new pan. You can find them on the internet quite easily.
Apr 01, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Whirlpool front load washer smells
I have a front load washing machine too and my instruction booklet says to run it on the clean cycle once a month with the bleach up to the max. I do this every month with out fail. I also the last load of laundry I leave the door ajar. It will usually dry completly in a few hours. Hope this helps
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Help
check:
1. the drain hose is not kinked or trapped.
2. look in the manual and see if there is a filter which you should have checked and cleaned in the last '3/4 year'.
It's unlikely to have anything to do with loading-a common misconception is that you can overload machines. It's much more common to underload, which causes out-of-balance spinning and walkies around the kitchen.
love, phil.
Mar 29, 2008 | Washing Machines
Long brewing time
Clean it out with 1/3 caraffe distilled white vinegar and 2/3 caraffe water. Once it is clean, it should take the normal amount of time and will make slightly less noise since it isn't busy steaming off as much water. Also, double-check the filter basket and make sure it is not slowing down the rate of draining coffee.
Mar 21, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
