Question about HP ScanJet 3530C Flatbed Scanner
My scanner doesn't work at all! If the lamp is burnt is it possible to substitute it?
  • 29 Answers
Not worth it. Buy another scanner. They're cheap now.
Posted on Mar 12, 2011
Copystar cs-1815 error code 3200, how can it be fixed
If it is a c-3200 code it means that you have a exposure lamp problem.Defective scanner,defective scanner PCB,lamp or inverter board,incorrect shading,poor contact of the connector terminals on lamp assembly. Look for a bad connection And look at lamp. Look for blue rings or burnt ends. Now don't look at that light while its on.
Feb 02, 2015 | Copystar Office Equipment & Supplies
I have a Philips 50PL9126D/37. I began having my screen go black (audio still playing) and a red light appeared in my blue power button. I removed the back of the television and checked the lamp, which was...
You cooould have a bad ballast, but it's probably either that you put the lamp in wrong, or you have a defective lamp though. There's a 33% chance that any of those are the case. Unplug the TV for 30 seconds. Plug it back in. Try turning it on again. Make sure you didn't over tighten the lamp during install. Especially the screw on the side. It should be a tight connection. Send the lamp back and get a new one. Usually they come with a warranty. If the new one doesn't work, it's either the ballast, or the power supply.
Jun 16, 2011 | Televison & Video
Canon np1530 copier e220 error message problem, how can solve this problem?
E220 is a scanner error. means:
the exposure lamp is burnt.
try copying with the top cover open, if the lamp does npt work, exchange it.
Good Luck.
Mar 12, 2009 | Office Equipment & Supplies
Scanner
SIR, YOU HAVE MENTIONED THAT SCANNER LAMP IS NOT GLOWING AND THE SCANNER IS WORKING PROPERLY;THE STEP THAT YOU HAVE TO TAKE ARE: 1.OPEN THE SCANNER AND SEE IF THE CARD IN SCANNING UNIT IS ALL RIGHT NOTHING IS BURNT. 2.IF EVERYTHING FINE IN THE LOGIC CARD OF SCANNING UNIT YOU CAN HAVE TO REPLACE  THE LAMP .
Aug 29, 2008 | HP ScanJet 2300C Flatbed Scanner
Fujitsu M4099D
First, you didn't say whether the Front lamps are actually lit. I know that it is difficult to tell on this model unless you cheat the lamp interlock switch and fire up the unit into scan mode.
Front Lamps errors can also be generated by a loose front camera cable. There are no dedicated lamp detectors. The 4099 uses the camera's ccd's to detect if the lamps are burning. It is also possible, but less likely , that the lamp fuse on the main board (slides out from rear) is blown. (Fuse part number CA53004-0227).
From previous experience, there is probably a 95% chance that the issue if coming from a loose front camera cable. Not the kind of thing to get in and check unless you are service savy. I have had several calls that drove me nuts with this issue until I reseated that cable onto the camera.
The Fujitsu service manual list these possibilties :
a. Do the Front side lamps lite up when you attempt to scan?
b. Is the lamps correctly seated?
c. If the lamps don't light up, possible lamp inverter problem or fuse problem.
d. Is the glass surface and white sheet guide clean?
e. Are the connectors at the front camera ccd loose?
f. Is the power supply output normal?
g. Possible front camera failure.
h. Possible connections from camera to the Rom board problem.
Jul 11, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Lamp failure
The E6 Scanner lamp can be substituted by a standard
F8T5CW lamp. It is 12 insches long, uses 8 watts, is in the
T5 tube size with two prongs at each end and cool white, not
warm white. The replacement lamp works fine.
Nov 13, 2007 | Microtek ScanMaker 8700 Pro Design Flatbed...
Misty white bands down the side of scan bed
That's a possibility If you were able to get these parts maybe the Microtek Technical support has some answers
Aug 05, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
AC instead of DC adapter connected to Visioneer 7100
The diode on the Power Supply Shorted and Possibly the Regulator also Check the Power Supply areas ttech
Jul 20, 2007 | Visioneer OneTouch 7100 Flatbed Scanner
Scanner
If the unit is in warranty, get Epson out to it. If not check the simple things like making sure the head lock is not on. Look to see if the scanner head starts to move at all when you power up the unit. If the head does not move at all or makes an unusual noise, chances are the unit is complaining that the head is stuck or requires too much effort to move it. Other possibilities include a communication error between scanner and main board of the SPC or SPC and your computer - indicates broken connection or bad USB cable. POssibly a fault with the mainboard of the SPC itself. Error ?Cause *Remedy Scanner error ? Lamp has burnt out. * Replace the scanner lamp. ? Power is turned on without unlocking the scanner. * Unlock the CR. ? The scanner carriage is interfering with any other part. * Remove the obstacle. * Replace the scanner carriage unit.
Jun 22, 2007 | Epson RX620 All-In-One InkJet Photo...
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
HP ScanJet 3530C Flatbed Scanner Logo
Seeker5211
Seeker5211
