The pilot will not stay lit. Same problem as described by ajith_senasi Jan 21, 2011. Can I fix it myself?
  • 3 more comments
  • marfin Mar 12, 2011
    It is a Vulcan Freeloader 260 gas water heater. Not sure how old but I would say about 10 years or so. The pilot will not stay lit no matter how long you hold the button down. Thanks.
    Thank you for your detailed response. I will try to have a close look at it although it's difficult to see anything down there. It sounds a bit complicated to remove the thermocouple. Thanks again.
    Thanks Helpmech! So much I didn't know. It looks a bit complicated to remove the thermocouple. I don't really know where to start to dismantle it. The flame is yellow and as you say, lazy, but it is actually very difficult to see right in there. I think it looks like a very expensive job. Thanks again. Marfin...
    Dear Helpmech, is it possible for an uninitiated plumber such as myself to fix?
    Yes thank you, the advice was very helpful in explaining the reason for the problem. I now understand why the pilot continually goes out. It is a very difficult problem to fix without going to the great expense of calling a plumber. I'm wondering if I could do it with clear instructions.Is it possible? Marfin
  • 5,370 Answers
Please give more details,the model number and brand of the unit and how old the init is. Probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. If thermocouple is faulty it has to be replaced.------------- Keep updated,Thanks.Helpmech.
Posted on Mar 12, 2011
  • raj somaiya Mar 12, 2011
    Do you hear gas when holding down the pilot light button.If no then gas valve needs to be checked.or gas flow needs to be checked.Either the gas flow is low or gas is leaking or the gas valve is turned to off.----------
    The pilot assembly is stopped up. It will need to be taken apart, blown out or cleaned and re-intalled. The yellow, lazy flame is preventing the thermocouple from getting warm enough to allow the main burner to ignite. ------------
    check to see if your pilot light is hitting the thermal couple. thermal couple is the little rod type thing above the pilot light. if your pilot light is not burning properly [crisp blue flame] it will not heat the thermal couple properly. if all this looks good try loosening and retightening the thermal couple at the bottom of gas valve. you may have to have the thermal couple replaced. very unlikely the gas valve is bad.
    Clean the pilot assembly if has any orange at the tip. If its burning clean and blue, then its most likely the thermocouple. The thermocouple is a safety device that turns off the gas if there is no pilot light. If you look closely at the burning pilot light, there is a small metal tube that sits directly in the flame, with wires that lead back to the gas valve. The thermocouple generates a small amount of electrical current when heated by the flame. This current keeps the gas safety valve open. If the pilot light gets blown out, the current stops and the gas valve closes. When you light the pilot light, you hold down the over-ride button for about 30 seconds. This allows the gas to flow long enough to heat up the thermocouple and generate current and then you can release the over-ride button and gas will continue to flow. If the thermocouple is defective, then as soon as you release the over-ride button, since there is no electrical current, the gas will stop flowing and the pilot light will go out.
    This is a pretty common failure on water heaters and furnaces.The thermocouple needs to be replaced.-------------This should help.Thanks.Helpmech.
    Keep updated with the results and details.Thanks.Helpmech.
Why doesn't the pilot stay lit?
Why Does My Gas Furnace Pilot Light Keep Going Out?
santafeair.com/blog/.../why-does-my-gas-furnace-pilot-light-keep-going-...
Jan 10, 2014 - The thermocouple is the copper rod you see the pilot flame hitting. It's a safety device that controls a small valve to shut off gas going to the pilot ...
Aug 11, 2015 | Kitchen Ranges
The thermostat is broken in a Toastmaster Mod 324029G. Where can I buy a replacement? Jan Williams
Jan, As you should know "pilots" shut down all of the time...I would check with a pretty smart guy in Florida, e-mail macsplace@embarqmail.com...He has been around the world working on (with) pilots lighting them up and making sure they stay lit even as far away as istanbul turkey and ercan cypress...this guy could bring some light into your life, so to speak...Good Luck...
Aug 19, 2011 | Toastmaster Heating & Cooling
Pilot wont stay lit on waterheater. I replaced Thermocouple and that did not fix it. It will stay lit on vacation setting.
Most gas water heater problems can be fixed with yearly service that cleans burner and burner parts, checks gas pressure and bleeds air out of gas line, cleans air intake, and checks for venting and air intake problems.
Open following links for resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 27, 2011 | Water Heaters
Pilot lite does not lit please advise what to do.the burner stays on if lit directly with open flame.is this dangerous.
What you describe is typically caused by a faulty thermocouple. The thermocouple senses the heat from the pilot light and TURNS OFF the pilot when it no longer senses the heat.
When the thermocouple turns off the pilot, it's not necessarily dangerous, but the water heater won't turn on without help.
Mar 23, 2011 | Water Heaters
Hello! Yesterday some "click" sound came from my
The click you heard was the pilot light cutting off. Have you tried to relight the pilot to get it started again? If the pilot will light, but not stay lit, you will need to replace the Thermocouple.
That should solve your problem.
Mar 05, 2011 | Heating & Cooling
My gas dryer lights, but the light won't stay lit. How do I fix it myself? .
try clean wear the gas come out the pilot ligth before try this turn the gas off first
Oct 15, 2010 | KitchenAid Dryers
The pilot will only stay lit depressed, a few times I was able to keep the pilot on and start the main burner, once it goes on it onlt stays lit for aprox 20 sec
It sounds like you need to replace the thermocouple. It will cause the symptons that you describe. If it is just a flame rod then you may be able to just clean it with steel wool. Let me know what you find.
Aug 03, 2010 | Napoleon Heating & Cooling
How do I fix a pilot light that will not stay lit?
Check the gas valve. Sometimes the springs in the valve can wear out.
Another thing is the pilot itself. Inside the pilot is a little rod that stays heated to ingnite the igniter. It can become dirty or corroded and won't allow the pilot to stay lit.
Apr 19, 2010 | Vanguard International Blue Flame - Large...
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Wall mounted CBN30T, pilot goes out
IF its balance flue it could be blocked . Burner or orifice blocked lack of air to pilot slightly blocked thermocouple defective .
Mar 03, 2017 | Desa International CBN20T Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
