Question about IBM Computers & Internet
How do you get an IBM Thinkpad OUT of Sleep Mode?
  • 3 more comments
  • Jenn Johnson Mar 12, 2011
    When I TRY to turn it on...it starts up
    Can't do an update! It won't turn on.
    Have had the battery pulled out for over an hour put it back in...still only comes on for about 3-4 seconds then shuts itself off again. I also tried pressing
    Earlier today the laptop" freaked out"
    So basically what you r saying is....I m SCREWED!? It was plugged in, cause I thought the battery was dead. That didn't help. Although for the amount of time that it is on(3-4 seconds) is just like what happens when has dead battery. But as it's trying to turn on the little" Z" lites up (on bottom of screen bezel) as well as the" moon" lites up too. So I figured it was in sleep mode.
  • 27 Answers
Usually you can press the power button once and it will turn it back on. If that doesn't work then one way would be to pull the battery or press and hold the power button.
Posted on Mar 12, 2011
  • 29 Answers
Normally by pressing the power button. If this doesn't work, you may need to do updates from the manufacturer's website.
  • phi-nom Mar 12, 2011
    So did you say it powers up after shutting it down? If it does, I would go to the manufacturer's website and update all drivers. But if you can't get it to boot up, you may have corrupted the OS and either do a repair or wipe and reinstall.
  • jollywg Mar 12, 2011
    If you dont have the power cable plugged in try that, it could just be a dead battery.
Whait display
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Hibernate
When Windows opens then -
Open Control Panel - then click on Power Options - Click on Hibernate tab and uncheck Enable Hibernate - Click OK
Posted on Feb 13, 2009
SOURCE: Can't wake up my Thinkpad..
Try this, Remove battery, Remove RAM, wait... 5 mins, replace the RAM, Then, Plug in the Power supply ONLY. Now press and hold the Power Switch. It should come on.. When/if it does, Shut down as normal, and replace the battery and try again... If it doesn't work now with battery, battery is faulty, or too flat to be any good.. Try an 8 hour, or overnight charge. & try again, if still no good, it is a battery problem,. If not. then you have another sort of problem that you will have to troubleshoot.
Posted on Mar 04, 2010
  • 485 Answers
SOURCE: My IBM ThinkPad A30 indicate
Usually, it wakes up when you touch a key, or the track-point (mouse). If it still doesn't wake up, you may want to press the power switch ... or hold it (down) for 4 or 5 seconds or so ... but it may (shut-down and) reboot the computer.
Posted on Feb 10, 2011
How to reset IBM thinkcentre sleep mode
Tap the start button/power switch once
Oct 26, 2013 | IBM ThinkPad T23 2647 Notebook
I can't get my IBM ThinkPd out of sleep mode. (I'm using another computer right now.) I tried taking the battery out and unplugging it for 20 minutes, pressing power button, holding power button down,...
It sounds like a failed motherboard, If it was stuck in sleep mode the computer would still turn on.
try leaving the battery removed plug in the laptop and see if it turns on, if not it sounds like a bad component on the motherboard.
Apr 06, 2011 | IBM ThinkPad T23 2647 Notebook
Ibm thinkpad t23, will not come out of sleep mode even when manually turned off and on. Cooling fan comes on, only blank screen.. I have removed battery and let it sit for a while, and then restarted it,...
Please press F8 at boot up and boot in safe mode. Restore to a previous date given in bold numerals.
Alternatively, after F8 select Last Good Boot up.
Mar 16, 2010 | IBM ThinkPad T23 2647 Notebook
My name is Luis and my Ibm thinkpad r40 keeps freezing and my screen goes black.
Hi, could be simply your computer is going into sleep mode and not waking back up. try changing your screen saver option to not hibernate or sleep.
Aug 18, 2009 | IBM ThinkPad T40 2373 Notebook
My computer does not go to sleep mode
Start > Put computer to sleep
This should work.
Aug 09, 2009 | IBM ThinkPad A21m 2628 Notebook
Doesnt come out of sleep mode
It could be the problem with graphics drivers. remove it and reinstall it.
Also cross check the Power Options under control panel.
Aug 04, 2009 | IBM ThinkPad R30 2656 Notebook
What does the half moon lit up mean, No screen.
The half moon usually means the computer is in SLEEP MODE. Normally, pressing the spacebar will wake the computer up but I have noticed that sometimes, the computer can get "stuck" in sleep mode. If that is the case, you can hold the power button down (until the power turns off and the moon disappears). Wait a few seconds then hit the power button again to turn the laptop back on.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
Hibernate
Feb 13, 2009 | IBM ThinkPad T23 2647 Notebook
Ibm thinkpad T-40 screen blackout intermittant
There is a toggle key that switches your monitor from on to projecter to dual monitors. If this key gets pressed accidently then the screen will to black. Try hitting the FN +F5 or FN+F6 keys at the same time. Push the keys down three of four times each. The sleep mode would change back to active mode if you re-booted your system.
Dec 25, 2008 | IBM A31 PENTIUM IV 1.6 GHZ...
How to get my ibm laptop out of sleep mode
have you tried charging it.. hahaha common mistake :S
Oct 21, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
491 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
