Question about Microwave Ovens
My oven is not getting hot but the light is working when you turn the knob.
  • John Tripp
    John Tripp Mar 12, 2011
    Model Number and Make?
  • 31 Answers
Your magnetron is most likely out. This you should not fix yourself. If your not attached to the microwave i would suggest just get a new one.
Posted on Mar 12, 2011
Shm1816s Samsung microwave oven wont shut off All lights off turn table not turning but you can hear the humming. the turn table plate gets very hot.
if the turntable is getting hot it means that the microwave is working but as the turntable is not turning , it means the adjustment of the door lock of your microwave may have become improper due to use.may be it got damaged.
call the technician of samsung microwave ,he will open the cabinet of microwave and make the adjustment of door lock proper.
Thanks
Nitin
Oct 19, 2013 | Microwave Ovens
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
Aug 28, 2011 | Microwave Ovens
Wont heat
Hi!
Here are two instances when this happens---
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Microwave don't work
You didnt mention if the oven worked or not. Its not blowing the fuse?? Ok it could be as simple as the Diode or capacitor but dont try to touch the capacitor terminals as it holds a nice charge.. Turn on the oven for a bit with a cup of water inside and let it run for a few minutes. If you start to see smoke pull the plug right away!!!!! If you dont let the water boil(about 2 to 3 minutes thyen unplug and carefully fell around for a HOT part, But dont touch any electrical connections! If theres something drawing to much current it will get hot. Ive had bad capacitors bad and causes the transformer to get too hot. as well as bad magnatrons cause the transformer to get to hot. I would recomend that you take this unit in to be diagnoised as there are alot of voltage in this oven as I ststed before and it is dangerous for a handyperson to be fiddling with it. Good Luck
May 30, 2006 | Sunbeam SBM1000 Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
