Question about Kitchen Ranges
30 code on maytag range
I have a Maytag range model #MES5752BAB, it is 5 mo old. The code 30 comes up on the screen when I push the bake button or the broil button, followed the clock losing time. Numerous repair men have looked at this range and tried replacing many things, the problem has not been solved. Please help me.
We've had the same problem. We bought this in March, '08 and noticed a problem within a short period of time. We finally called for service in October. The technician replaced the panel, but the new one started doing the same thing almost right away. I called Maytag to inquire about it. The customer service rep said she didn't have any notes pertaining to a widespread problem with it. I told her I was concerned about ours going out of warranty before the problem would be fixed and she extended it for another year. You may want to do the same thing. We have a technician coming tomorrow to replace it again. I'm going to tell him that I'm going to keep calling every week, if I need to, in order to get Maytag's attention to this problem. I don't want a "fix", I want a corrected panel- one that's perfect- straight from the factory!!
Check out http://www.fixya.com/support/t576160-maytag_slide_in_range fo others who also have this problem.
Posted on Nov 11, 2008
Maytag Stuck on "Delay"
You are in the Tiller and Cultivator section of FIXYA but have you tried unplugging or shutting off the Breaker for a few seconds and let the Oven 'reboot'? Ahh, what ever happened to the simple good old fashioned Ovens?
Jan 22, 2014 | Maytag Gemini 30" Self-Cleaning...
Baking display malfunction
Its likely sab as in Sabbath mode.
Here is your online use & care manual which explains all about the Sabbath mode on page 15:
http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf (http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf)
Mar 23, 2008 | Maytag MGR5750 Gas Kitchen Range
I have a maytag stove about 7 yrs old and the bake element dont work. What could be wrong
The bake element on any stove can burn out. It is easy to replace. First disconnect at least one end and check it with an ohmmeter. If it is defective, it will have a high resistance. I have bought replacement elements from RepairClinic.com.
Feb 21, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Display Malfunction
Hello murfraven,
Welcome,
You said, you went to set the timer while baking a pizza and I got a "set or en" on the display of my Maytag Gemini Ceramic Top electric oven.
How old is the range?
And the model number?
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the switch itself is bad.
Let me know how it works out.
Huuum, Please remember to leave a rating
Oct 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
My maytag oven's clock won't turn on. It just says "OFF", but there is a lack of a visible on button. The range works fine but I cant bake because I cant set the time let alone a temperature.
Hello roborrob,
Welcome to fixya,
You said, Your Maytag oven's clock won't turn on. It just says "OFF", but there is a lack of a visible on button. The range works fine but I cant bake because I cant set the time let alone a temperature.
What is the model and year of your range?
Try to turn off the rage and then throw the breaker of for 5 minutes and then see if this sresets the system.
How long has this been going on?
Or did it just start ?
And how log have you had this range working fine!
Huuum
Oct 06, 2008 | Maytag Kitchen Ranges
GAS OVEN DOESN'T HEAT
you need a new ignigter for the oven the one you has is weak or already died,it should be located near the burner
Jul 08, 2008 | Maytag MGR5750 Gas Kitchen Range
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
