Question about ASUS Eee PC 2G Surf Notebook
Bad bios checksum - ASUS Eee PC 2G Surf Notebook
  • ASUS Master
  • 32,281 Answers
The BIOS sum check has detected faulty BIOS information. This can occur when the BIOS battery is nearly flat.
Replace the BIOS battery and then go into the BIOS configuration and set the Date and Time etc.
Posted on Mar 12, 2011
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
Coooo221 Bad image checksum
Bad checksum means the file is corrupt or your BIOS is out of date.
You can be sure it is the BIOS if it is happening on different files.
please let me know the machine make and model and I can help you check the BIOS?
Dec 18, 2010 | Dell Inspiron 6000 Notebook
Bad bios flash, backup gives bad checksum error. downloaded correct ver - still bad checksum. what should I do? AMI bios ver 1.0
Is the mother board working? If so, why are you flashing the bios? If the bios is bad and can not be flashed, you may be able to buy a pre-flashed chip if it uses a removable flash chip. Try this site but you can find others on the Internet.
Mar 24, 2010 | Intel Motherboard
BIOS ROM checksum error
sounds like your bios is corrupted, try going to the motherboard site and update your bios software. It could also be bad memory modules.
Nov 01, 2009 | HP Computers & Internet
CMOS CHECKSUM BAD USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECS there is no shortcircuit in usb header 5v is ok i also upgrade bios but it did not solve this error
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
Apr 05, 2009 | ASUS P5RD2-VM Motherboard
"Bad Bios checksum P/N 113-PE0600-04
replace the bios battery.... looks like a big watch battery.
Mar 04, 2009 | ASUS P4V800-X (90-M8LBR0-G0EAYZ)...
Hard Drive will not boot in Compaq Presario C700
BIOS checksum errors occurs when either the BIOS chjp is faulty or most likely the BIOS battery is nearly flat and the stored info changes and doesn't match the checksum info.
Replace the battery with a new one, leave the battery out for 1/2 hour before inserting the new battery. The BIOS will be reset to the default settings, you need to configure it again eg, datr and time etc.
Feb 22, 2009 | Compaq Presario C700T Notebook
Checksum error in bios
the on-board battery may be bad-try replacing it.
Jan 12, 2009 | Computers & Internet
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
ASUS Eee PC 2G Surf Notebook Logo
403 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
