Question about ViewSonic VG700b 17" LCD Monitor
The monitor works when connected to my laptop but when I connect it to my desktop, I get a little message box that says Out Of Range?
  • ftoomer Mar 12, 2011
    I lowered the screen resolution to the lowest setting 800 by 600 pixels and nothing changed. when I restart, he monitor shows everything through the startup process but then goes black with the little message box
  • 27 Answers
Right Click on your desktop go to Properties (for xp) or Screen Resolution (win 7 and vista) lower the screen resolution. What the error means is that the resolution is too high and the monitor cant handle it.
Posted on Mar 12, 2011
  • jollywg Mar 12, 2011
    Is this a windows 7 xp or vista machine?
    windows XP
Problem with the monitor
hi,
first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
Aug 25, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
Moved my LG LCD monitor to my home office but do not have any manual. My screen is all black with a blue box with the message Analog out of range 53.6kHz/85Hz I have loaded the users guide and it...
you need to plug in a different screen and change your video card settings to: screen refresh rate: around 60hertz if your running XP right click on the desktop and click properties>settings tab>advanced settings>monitor tab> and there will be a drop down of options... set it to 60 hertz then you can plug your other monitor in and it should work! good luck
Mar 30, 2011 | LG Computers & Internet
Monitor has small message box saying Out of Range when connected to my PC but works fine when connected to laptop lowered to 600 to 800 pixels and notheing changed
It means that the maximum resolution of your monitor is 600 to 800 only. Anything that's higher than that will not display the screen. Although you can try setting it a bit higher because most of the monitors have a standard screen size of 1024 x 768 but if it's a VGA monitor, chances are the max size is already 600 x 800
Mar 12, 2011 | Computers & Internet
Hi,please if you can help me.I have NEC MyltiSync FE 1250 monitor.It stoped working when is connected to desktop,it has light on but the screen is blank.I've connected it to laptop and it works fine but...
You have proved the monitor is OK.
If the desktop appears to boot up then the most likely problem could be a faulty video card OR the video card setting has been changed that is outside the range of the monitor's capabilities, ie, the refresh rate set too high (set it to 85Hz or less) or the screen resolution is set too high (set it to 1024x768).
You may need to connect a different monitor to the desktop to get a display to lower the video settings.
Sep 03, 2010 | NEC MultiSync FE700 17" CRT Monitor
An Out of range box
frankr2327
If you are getting this message this means that you are connecting a device to the monitor and/or a connection that is putting out a signal that is not supported but the monitor. You may also need to look at the cable you are using. Example I have an XBOX 360 with the official VGA cable when I use it to connect to my monitor it works fine. However I have been testing cables to get a setup for my PS3 as I have not been able find an Official one from Sony. So when I connect my RBG to VGA cable to the end of my RGB XBOX cable then to my monitor I get an Out of Range message. So something with the cable is case a problem with the signal to not to be sent properly.
Note with monitors they have a safety feature that they would turn off if they got a signal they did not properly support and/or not read properly. This has always been there they just not got where they would show you a message. Plus with monitors getting bigger they have stopped supporting lower resolutions so you may see this issue more often when hooking up older devices. I my self still have a 15 and 17 inch on my work bench for toubleshooting.
Hope this helps clarify things. Feel free to reply back with what device you are having trouble with.
Issken
Dec 30, 2009 | Envision Computers & Internet
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
No video out to monitor from desktop.
sure not hard at all. if the monitor is connected to the default onboard video adapter, this is usually one of the first things to malfunction on a new computer. if the monitor works when connected to another machine, but when connected to the desktop the monitors amber or orange light comes on but no video, this usually means there is a connection problem. usually most modern monitors will display a "no input" or "no video" message meaning the connection to the computer is bad. try getting a new video adapter (usually pci/pcie video card) and installing into the pci/pcie video slot in the back of the computer. most are plug and play and require little to no configuration. you should be able to find a nice one for about $20 - $30 dollars at www.tigerdirect.com . hope this helps. please rate me and thanks for choosing enterprise computing solutions.
Oct 07, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
How can I
Normally a laptop has an external video output in the form of S-Video, VGA, or HDMI. Once you have connected the laptop to the television through one of the available outputs. You will have to enable the external video out on the laptop. Normally this is done by pressing the FN and a labeled F key. Example: If the laptop was a HP you would press FN + F4 to enable the external monitor. Gateway, eMachines = FN + F4. Dell FN + F8. You will have to look at your keyboard close and look for what looks like a little monitor. That key + FN will most likely be how you enable the external monitor.
Once connected, you use the FN + F4(from example) to cycle through the video modes. The video modes are usually Laptop LCD and external monitor, external monitor only, Laptop LCD only,
If you would like to extend your desktop to the external monitor instead of clone the desktop than you will have to go into your display properties and click on the second monitor and check the box that states "extend the desktop onto this monitor". This will allow you to drag windows from the laptop LCD to the external monitor.
Mar 29, 2009 | Vizio L37 Television
What does out of range mean on my asus lcd monitor i am trying to hook up my ps3 through my vga port
Out of range is comes when the monitor is not working with the cpu. May be you are not connected it well . and you can see the message out of range when the operating system is shut down.If it shows message when the cpu running please connect the vga cable into the graphics card port.
Apr 29, 2008 | Computers & Internet
ViewSonic VG700b 17" LCD Monitor Logo
80 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
