Question about LG LHD65EBL Dehumidifier
Low on freon - LG LHD65EBL Dehumidifier
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on Mar 30, 2011
Kenmore dehumidifier 25358400890 sometimes works, but sometimes won't run. Light comes on when bucket is removed, so it's getting power. Any clue why?
Assuming you've turned the humistat all the way to the maximum dry setting, it's possible it's not humid enough for it to run but fairly unlikely. The humistat may need to be cleaned or replaced or the compressor may be low on freon. If it works in hotter temperatures this may indicate low freon. Freon pressure increases with temperature therefore if it's hot, the pressure inside may increase enough to satisfy the low pressure switch.
Jun 01, 2014 | Dehumidifiers
Low on freon
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
heatman101
May 31, 2011 | Maytag Dehumidifiers
Low on freon ! Unit runs, but ice forms on short length of pressure line and coil does not get cold.
Yes, this is low on freon and the things you are describing are typical symptoms of that,,,
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
May 24, 2010 | Haier HDN655E Dehumidifier
The compressor clicks on for a few seconds, then clicks off. Is this a problem with the compressor, or could it be the relay
This could cover a lot of territory...low freon, compressor running hot, bad start components/capacitor.
The general result is that to repair a unit like this costs nearly that of a new one if not more. These are sealed units, thus if low on charge it requires addition of service port and freon....and hopefully find the leak. If not freon related, it still requires some tight troubleshooting.
These are difficult to work on due to how they are setup and assembled
Mar 31, 2010 | Kenmore Dehumidifiers
Coils icing
the unit either has dirty evaporator coils and this will make them ice up,or the unit is low on refrigerant/freon,try cleaning the whole unit of dirt and dust first,then you may need to install a saddle tap on the sealed system and add some refrigerant/freon as these systems seem to leak more often than other sealed systems
Feb 06, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Freezes up
first clean filter also check fan is operating if the evaporator is clean then check freon pressure may is low so youhave to repair the leak and recharge with freon.
Sep 23, 2009 | Dehumidifiers
Ice forms on the coils of a white westinghouse dehumidifier
if the filter is clean than it most likely is low on freon with the right tools you could add freon
Jul 06, 2009 | Dehumidifiers
Kenmore dehumidifier runs good but does not collect water.
most likely the compressor is not producing pressures that are needed probably not low on freon .
May 31, 2009 | Eva-Dry EDV300 Dehumidifier
LG LHD65EBL Dehumidifier Logo
291 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
