Hi, I have an older tv and had lost the remote, tried to use a universal remote but fail. Now I have found the remote that goes with the tv but the tv won't respond to it. I made sure it's not the batteries,put in brand new ones and the indictator light is working. How do I reprogram the remote to the tv. On the remote it has RC-S11P-OD. Help will be much appreciated! Natalie Lum
  • 38 Answers
If your phone having a camera please shoot your remote sensor to the front and dont capture your cam it continued shooting after you see the sensor is lighting that is good but no light it is bad or you never press the key of the remote..
Posted on Mar 12, 2011
Need remote code for zenith tv/vcr TVBRO922Z
You can try using a universal remote control and performing a code search. If nothing is found, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Nov 22, 2017 | Zenith Televison & Video
I am looking for the universal remote code (mine is a Sony RM-EZ4 remote) for an older model of White-Westinghouse 13" colour tv. Model # is: 61304. I have tried several 4 number codes I found on the...
Use the code search function of the remote to find something that works, even to a limited extent. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jun 24, 2017 | Westinghouse Televison & Video
My universal control wont pair with my t.v, i have done everything the instructions say and it still wont work my control is a urc-22b and my t.v is a sanyo, please reply kind regards, aaron
If your remote was built and programmed less than 6 months before the TV was released or the TV is newer than the remote, then the codes in the unit will not include your TV. There is a lag in the codes being provided to the companies that build universal remotes.
Please check the date on the TV, since I see that the remote may have been released in 2006. It could be older than that. (There are requests for help with the remote with November 2006 dates that show up on a google search.) If the remote is older than the TV, try a newer universal remote.
If the TV actually is older than the remote, then try a different universal remote to check if the TV's IR receiver has failed or if the remote has failed. Some TVs can respond intermittently to a remote - hitting the sensor may bring the response back temporarily. Then you may be able to find a replacement receiver (try stores like shopjimmy.com or partstore.com). If hitting the unit works, you could try just resoldering the receiver to the board. (A solder joint that swells and contracts can lose contact between the board and the parts on the board.) When searching for parts, open the TV and find out the part number on the board that needs to be replaced. Some sites may have the part but not list the specific TV model that you have. The parts are often used in several TVs.
I hope this helps.
Nov 19, 2010 | Universal Remote Control Remote Control
Hi Lost instructions. Would like to obtain how to program my Philips Magnavox remote. Don't know if the #2 MP#20C103-1 or the 1-0010 are the model #s. Thanks
Turn TV on, press and hold CODE SEARCH button until light comes on, press TV, the light will blink and remain on, enter the code, the light will go off, press POWER untill TV goes off....hope this was helpful...
Apr 23, 2010 | Philips Magnavox Learning Universal Remote
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Toshiba television and universal remote problems
Hi, as the sets get older the codes for older models get deleted to make room in the remotes memory chip for the newer models, this is probably why none of the universals will work for you, post the model number found on the back cover of your tv & I`ll look it up to see if theres a sub or the original is still available, video-tek
Jun 05, 2009 | Televison & Video
Code for rca remote for operation of orion tv
I have an Older Orion TV and have tried all different kinds of remotes. The thing is that Orion does not sell their codes to universal remote vendors. I have the best luck out of Philips remotes.
Mar 29, 2009 | Televison & Video
Programming the ramote to tv
i dont know how to program the remote for tv..i got the codes
Feb 28, 2009 | Philips Magnavox Learning Universal Remote
Need the tv coes for my toshiba tv
I have a older Toshiba TV CE20F10,but I lost the codes tomy TV,Ineed them.Tkank you
Dec 12, 2008 | Toshiba CT-90157 Remote Control
Televison & Video Logo
Top Televison & Video Experts
