VOLUME CONTROL WILL NOT WORK ON 2ND HAND RECIEVER SON BOUGHT. PRE TEEN COULD NOT AFFORD NEW, SO LOOKED AT REVIEWS AN RISKED USED. I DO NOT WANT HIM DISCOURAGE BY BUYING A BROKEN UNITE BUT CANNOT FIND ANY INFO ONLINE FOR FIXING VC WOULD BE SO APPRICIATED BY A A MOTHER THAT ENCOURAGED HIM TO NOT NEED LATEST AND GREATEST AND BE WILLING TO PUT IN WORK TO CLEAN UP.
  • 31 Answers
I would make sure your speakers are correctly connected. Some times older receivers will say speaker A and speaker B on the back. Connect A. on the front there should be a button that says A and B. press A. This will tell the receiver which channel to use for sound. Try just using FM first to see if any sound comes out. If this doesnt work you might have some other problems. also you should include what brand and model number Receiver you are talking about.
Posted on Mar 12, 2011
What might make a preamp in a reciever just stop working?
If when you switch to the main amp you have to turn the volume up really loud to hear it, then it might be the pre-amp IC has failed, though it is passing the signal from the inputs. Though I'm concerned that the surround functions are also not working. You might need to look into the circuit around the pre-amp more closely. There might be another IC device that controls more of the functions that is playing up instead. You will clearly need the service manual for this problem.
Mar 10, 2016 | Audio Players & Recorders
2nd hand gateway laptop
1 - remove all of the startup programs - go to run and enter msconfig, hit enter, enter startup and remove all of the checkmarks that appear
2 - disable auto updates, defender, firewall
3 - turn OFF all anti virus programs that you have running using up valuable resources.
4 - reboot.
Apr 01, 2014 | Computers & Internet
Review Miroil P36 B FryPowder
Oil wears out and gets contaminated. If you overload the fryer the temperature will drop and your food will adsorb it and contaminate it. Watch the temperature when you load it, I had a limit of 10F drop. Pre-cooking your frozen items will help a lot. I would replace the oil on a weekly basis depending on your volume. Empty the fryer, clean it and filter the oil every day. This will help a lot.
Mar 26, 2014 | MIROIL P36B Frypowder 240ml Portion Pack...
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
I have a JVC A-L55 and I just plugged it into a reciever. It is working fine but the volume is very low. I have to turn the volume on the reciever all the way up to hear it. The reciever is attached to new...
You need to find out if your reciever has a "magnetic cartridge pre-amp" built in. Many don't and it's no good putting it in an aux or tape socket. If it doesn't say 'phono' or 'record player' on the socket it probably won't have one. Don't worry you can buy one, which will restore the normal sound level.
If it does have one it could be faulty. They are often a single IC that has failed, but they tend to kill the sound dead when they fail, so I don't think that will be your problem.
Just put the words "magnetic cartridge pre-amp" into Google to find one.
Nov 16, 2010 | Audio Players & Recorders
Just bought 2nd hand jazzy select 6 ultra v v slow !!
The unit can be programmed to run faster. Stop in to the local powerchair dealer in your area. Very quick and inexpensive fix. I would charge you only for my time. About 10minutes max.
May 15, 2010 | Pride Jazzy Select 6 Indoor Power...
88 jeep cherokee. Auto Window won't go up,Single mom needs help!
Mine has the same problem. I tapped lightly on the motor, which is inside the door panel directly below the arm rest-door handle. It went up ok. I was told by a friend this morning you can take the electric motor out, open it and clean the brushes inside and it would work like new. I am in the process of doing that now.
Apr 27, 2010 | 1988 Jeep Cherokee
Low sound at high volume
THe problem is with the variable resistor present behind your volume control knob, try replacing the volume controls variable resistor, this must work fine... this is a common prblem for all the music equipment that has knob control for the volume....
This resistor can be replaced with your product warranty, contact your seller for the details regarding warranty...No need to woory about this, this is a sommon problem for most of recievers
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 04, 2009 | Sony STR-DG1100 Receiver
Hi ! i have bought a 2nd hand samsung e350e
contact your operator they ´ll send you a sms to configure your phone
Jun 05, 2008 | Samsung SGH-E350 Cellular Phone
Denon Avr-1803- multiple room audio difficulties!
it is true pre amp check your cables and confirm in (avr-1100)that you select the right input.
May 27, 2008 | Denon AVR-1803 Receiver
129 people viewed this question
 Grubhead
Grubhead
