Question about Deni Ice Cream Makers
I don't know what model deni ice cream maker i have. it is small, the motor is in the top,, a stirring paddle attaches to the top and the top goes over the speedy bowl, I am trying to find instructions and recipes
  • 2,382 Answers
Hi, you can download the user manual/instruction and the recipe from the Deni website by scrolling to the bottom of the the website on this LINK.........
Posted on Mar 12, 2011
Does the paddle in the cuisinart Ice 21 ice cream maker suppose to move
yes, the paddle moves to stir the concoction and make it into iced cream.
Mar 31, 2013 | Cuisinart ICE-21 Ice Cream Maker
I was given this never used ice cream maker, but there is no manual or paddle to churn the ice cream. where do i get these things? thank you kylee therrien kdt_1958@yahoo.com
I've located the manual for the Deni 5000 below. The file is in PDF format. The manual includes recipes and instructions on how to make certain types of ice cream flavors.
http://www.deni.com/files/5000.pdf
As for the paddle, Deni doesn't sell the individual parts on their online store, so you should contact their team (which can be found via http://deni.com/index.cfm?fuseaction=page.contactUs) and ask them about replacing your single paddle for your unit. Their customer service is lovely so best of luck to you!
Mar 27, 2011 | Deni 5000 Scoop Factory 1.5 Quart Ice...
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
I need an instruction manual for my Deni 5000 ice cream maker
Are you looking for operating instructions or reciepts?
Find receipts via Google.
Operating instructions:
place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
I sometimes add a quart of water but you dont have to.
The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
Enjoy your delicious home made ice cream.
(BTW - the paddle does not move ... the can spins around the can causing mixing.
a
Oct 14, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
Not setting / freezing - bowl in freezer 24 hours *
The ice cream mix has to be xconstantly stir in a nrine solution, That's why they have motorized ice cream makers that rotate the can surrounded by ice and salt.(brine) while a paddle inside stirs it. Good luck and enjoy.
Jun 01, 2009 | Disney Ice Cream Maker
Deni Ice Cream Maker Manual
I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
2. Prepare your ingredients ahead, and chill them for best results.
3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
6. Turn the On/Off dial to the right (on position).IT IS IMPORTANT THAT YOU TURN THE UNIT ON BEFORE POURING IN THE MIXTURE. THE CANISTER ROTATES WHILE THE STIR PADDLE REMAINS STATIONARY.
7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
Hope this helps... If you need something else, let me know. I will try to check back soon.
Apr 14, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Deni blueberry 5201 Ice cream maker...
While I can't tell you where to buy a replacement paddle, I can tell you we just bought this model of ice cream maker through Heartland America for $30. If all else fails... Hope this helps!
Jan 12, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Ice Cream Makers Logo
217 people viewed this question
Top Deni Ice Cream Makers Experts
vince
NOEL
NOEL
Are you a Deni Ice Cream Maker Expert? Answer questions, earn points and help others
