The TV was not used for last 3 years but it was working fine before that, when I try to start it now it seems like it is in sleep mode the light turns green and then turns red again and blinks
  • Televison & ... Master
  • 1,212 Answers
This is a common occurrence in many flat screens. And the most common problems are bad capacitors in the power supply board! Hope this gives you an idea of the problem here. Thanks for asking and show a few hands of support!
Posted on Mar 12, 2011
I have a mitsubishi ws-65313 projection tv i was waching it and went black now its not working the green light is on but tv isnt working and i try to turn it off and the ligth still on i push the botton...
Hi. i believe this to be either of these three problems.
1. Power: it could be that there is a problem with the power electronic element(s). the solution is to go see an engineer.
2. Screen: if the television uses LCD display, it could be a problem with the liquid in it. Solution is to see an engineer.
3. Sleep mode: the TV could be in sleep mode which makes the screen go blank until removed from sleep mode. Solution is to read the TV's users manual to see how to wake a sleeping TV. Get back.
Jul 15, 2011 | Mitsubishi Televison & Video
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
Dell w2600 wont turn
Same problem, this is my solution. The system will start everytime if starting from power off one starts from sleep. Thus the trick is to use sleep mode to shut it down. I do not use the sleep function on the remote (it would be worth a try, let me know if you do that), but rather I have chose VGA as the entry signal ad have hooked the TV to my PC, and then I put the PC in sleep mode. The TV will do the same. When it is in sleep mode through the PC, the system cvomes back to life if the remote from the cable is used to change channels.
Feb 28, 2009 | Dell W2600 26 in. LCD Television
Compaq Presario SR1123WM PC Desktop will not start up.
try starting it in safe mode, when click the power bottom press f8 repetitively then select safe mode. then restart it again.
Dec 03, 2008 | HP Compaq Presario SR1123WM PC Desktop
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Toshiba Laptop Stuck in Sleep/standby Mode
maybe u got problem with the flex cable that connect the lcd to keboard/mouse
Aug 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Batteries Dying Quickly
Change the internal rechargeable battery.
Dec 01, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
