Question about DR Scholl's Health & Beauty
Point E, F,G,I, arranged in a line in such a way that F, is between G and I, and E is between F and I, if E proceeds G, in what order are they arranged?
possible answer
G F I or I F G
possible answer
G F E I or I E F G
E proceeds G
answer
I E F G
G F E I was eliminated because
E succeeds G
Posted on Sep 14, 2012
Egfi
Posted on Aug 13, 2011
    Novelist:
  • 117 Answers
The answer is:
iefg
I hope this is correct.
Posted on Mar 12, 2011
Firing order on cap for 1988 honda prealude
6 cylinder firing order is usually ,153624. Fours are 1342.
Turn the engine by hand (use the fan belt or a spanner or socket on the crank pulley until the timing marks line up. The position of the distributor rotor should either be at number 1 or it will be 180 degrees out. Place lead from number 1 directly into the plug hole in the cap that lines up with where the rotor is pointing. Arrange the remaining plug leads in the order as above. If it doesn't run or sounds like the motor is locking up, it would mean the timing is out. Repeat the process again. Try and get confirmation of firing order from a Honda dealer. Good luck
Dec 03, 2014 | Cars & Trucks
Need to program the rca-rcr312wr remote to my magnavoxx-mwd2206
There are several ways to program RCA remote controls, and all are related to its model number. Some models will have the same setup proceedings. Your remote control model specified here will have same setup proceeding to RCR312W mode. Just visit the site linked here for a detailed description about the setup procedure.
Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name at first.
Dec 20, 2012 | Televison & Video
Remote setup
Setup proceedings to URC remote controls are different to various models. Here you specifies that the remote control mode is URC40636. It seems that there is no such model to URC remotes. Might be wrongly typed in. Anyway, enter the site linked here to see whether there is setup proceedings to your remote control. There are setup proceedings in detail. Check it.
Dec 20, 2012 | One For All Televison & Video
Onn magnavox tv codes
Setup codes for Magnavox TV are: 0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141. For more codes and details about setup proceedings, click here. . Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, by brand name at first
Dec 18, 2012 | Philips Televison & Video
My photos show up all mixed up, not in chronological order
Why not download them onto your computer (in a folder of its own) then arrange them yourself. Try this>
  1. right click anywhere inside the folder window
  2. from the pop-up menu, select anyone of the following - depending on your preference. Point to sub-menus 'Sort by' and 'Group by' under Arrange by menu and you can choose Name,Date,Tag etc. Your pictures will be arranged automatically for you.
Oct 28, 2012 | Canon PowerShot ELPH 110 HS 16 Megapixel...
Replaced fuel line and now petrol comes from fuel bowl is there a gasket between fuel bowl and body please?
No, Go online to www.cycleparts nation.com and proceed to look up the part for carburator assembly that you need and at that point order the part that you need for your carb. You need to look for a carburator bowl gasket for your particular motorcycle.
Good luck my friend,
kd4rua
Dec 29, 2011 | Motorcycles
Vw jetta 2007 bkd engine whatare cylinder head bolt torque settings
I had a quick look online for these specs. according to several sites I visited, these are the correct specs.. Have fun.. 1.8L Turbo
  • Volkswagon's 1.8-liter Turbo engine has 10 head bolts arranged in pairs across the engine. The bolts should first be pre-tightened to a specification of 40 Newton Meters (Nm), starting with the middle two bolts and proceeding in sequence out towards either the left or right end of the engine. The bolts should then be tightened again in the same sequential order by making a one-quarter turn of the wrench, and then tightened once again with another one-quarter turn.
  • 2.8L V6
  • There are 20 head bolts arranged in three lines across Volkswagon's 2.8-liter V6 engine. The bolts should first be pre-tightened in sequence to a specification of 50 Newton Meters (N-m), starting with the first bolt that is situated in the center of the engine block between cylinders 3 and 4. Proceed tightening the bolts in sequence out towards either the left or right end of the engine. The bolts should then be tightened again in the same sequential order by making a one-quarter turn of the wrench, and then tightened once again with another one-quarter turn.
  • 2.0L L4
  • Volkswagon's 2.0-liter L4 engine has 10 bolts that are arranged in pairs across the engine. The bolts should first be pre-tightened in sequence to a specification of 40 Newton Meters (N-m), starting with the middle two bolts and proceeding in sequence out towards either left or right end of the engine. The bolts should then be tightened again in the same sequential order by making a one-quarter turn using a box wrench, and then tightened again with another one-quarter turn.
  • Dec 19, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
    In what order do yu arrange the plug wires on the distributor cap or a 1990 gmc 350
    1-8-4-3-6-5-7-2 Distributor turns clockwise Number one should be in the 5 oclock position. You should be able to draw an imaginary straight line between the coil tower and number one tower on the cap and the number one spark plug.
    May 15, 2009 | 1990 GMC Sierra
    Arrangement of speakers
    First you need to put speakers in horizontal line and high where you will be seating. That must be your center point. Focuses all speaker in that point. Subwoffer must be in fron of you and the central speaker. With satellite do what I say for center point!
    Good luck
    Feb 09, 2008 | Audio Players & Recorders
    Health & Beauty Logo
    806 people viewed this question
    Top DR Scholl's Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a DR Scholl's Health and Beauty Expert? Answer questions, earn points and help others
