Question about RCA DRC212N DVD Player
When I turn my DVD player on and put a DVD in, the DVD plays automatically until the menu screen comes up on the TV. At this point, the display on the DVD player shows "root" and I can not select or move around on the menu as the remote does not respond. I have changed the batteries and that has not resolved the problem. Is it possible that my DVD remote is no longer set / programmed to operate the DVD player? I would appreciate your help! Thank you.
  • james_marysv Mar 14, 2011
    As suggested, I started the DVD by pressing the play button on the DVD player. Whatever the issue was, the DVD player is now responding to the remote. Thank you!
  • 31 Answers
The remote could be broken. What happens when you press play on the DVD player this should start the movie. You can buy a cheap univesal RCA remote if you need to replace the old one.
Posted on Mar 12, 2011
Hi, I have a Sharp DV-RW360H which has been working fine. I have dubbed various VHS tapes to DVD and now need to finally the discs so they can play in other machines. However when I press the setup button...
Try one of the discs in another machine. You only need to finalise them if you want to ensure no more is put on them. To finalise a disc you need to use the write or burn functions, not the setup menu. Get the manual for this from the sharp website and read it.
Dec 15, 2013 | GoVideo DV2130 DVD Player/VCR
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Can't get new DVD player to play
On some sets there is a button on your remote marked "TV/VIDEO" or some such text. With your tv and player hooked up and working, pushing that button will switch from TV to video and back.
On other sets, if you keep changing channels, you will eventually come to one that turns off the video broadcast and plays the DV.
Good Luck
Mar 13, 2009 | Sanyo Televison & Video
Wont play dvd jensen vm9311
You can bypass all that. Here's how:
This will work without having to do anything to the pink wire - just tape it and leave it alone. But the next time you unhook your battery cable you will have to put the code in again.
Put in DVD
When the blue screen comes up, hit STOP twice on the remote
punch in 1,2,6, and 4
hit DOWN 1 time
hit PLAY/ENTER (although you can't see it, this turns off the parking brake bypass security feature)
**at this point the display became visible and you will now see the menu which makes it much easier.
hit DOWN one more time to change macrovision
hit PLAY/ENTER
hit SYS SETUP twice to save and exit menu
From now on, you can just put in a movie and it'll start - no more grounding or toggle switch procedure, and you don't have to use the e-brake.
Oct 22, 2008 | Jensen VM9510 Car DVD Player
How to unlock it to play either NTSC/PAL
Here is the sequence to unlock your DV Player. Clearly this needs to be done exactly to access the secret menu. So, you may want to copy and paste this info into a word program and then print it.
- Begin -
1. Turn off NS55P, leave TV on.
2. Using the original remote supplied with the NS55P, press these buttons in order: DISPLAY, TOP MENU, CLEAR, POWER.
3. NS55P will turn on, displaying the secret menu on the tv screen.
4. Select 2: Drive Manual Operation, then 4: Tray Aging Mode.
5. The screen then shows two input lines: Input Count and Current Count. Use the code 00030 on the first line. Pressing zero first will take you back to the original menu, so instead of trying to type 0-0-0-3-0, try something like 1-0-0-0-3-0 so the 1 in the front disappears after the last zero is entered.
6. Press ENTER on the remote. Disk tray will then open and close automatically 30 times. Let it do this until it finishes.
7. Repeat steps 4-6, but instead of using 00030 in the Input Count, use 00000. Press ENTER, and the NS55P is now capable of reading Region 2 dvds.
- End -
Please ask any questions using the comment box below.
Regards,
Worldvet
May 22, 2008 | Sony DVP-NS55P DVD Player
Sony DVD player color adjustment (Model #DVP-N5400D)
Solved the problem!Well, After reading two manuals on the Sony DVD player, I saw one cable not connected: the S Video connection. I connected that. Tried it out again, seemed a little better, but still not the full range of reds. At that point I thought the problem was either: 1) the cables from the DVD player to the TV or 2) the DVD player is the problem So, I thought I'd start with replacing the cables. Labeled them as to where they went, took them out and went to Radio Shack and explained my problem. The clerk I spoke to was very nice, said he had seen this problem before, and said there was a menu on the DVD for adjusting RGB settings.
So, I went back home, plugged in the cable, and went all thru the 2 Sony DVD booklets and the display menu on the TV. There was nothing mentioned re: color settings. Went thru the DVD menu many times, looking, looking. I felt I had come up with nothing.
Turned everything off. Turned back on. Put in a DVD: It looks great! :)
So, hoping it never happens again..cause I'm not sure I can repeat it! Maybe it was removing all the cables from their sockets and restarting...I know that sometimes works with computers...anyway.. At least I didn't have to buy a new DVD! Lesson: unplug, re:plug...before you trash it!
M~
Mar 06, 2008 | Televison & Video
Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
Feb 19, 2008 | GE 25GT240 25" TV
LG DK 8621P DVD Player only play the audio (no video out)
how can off the progressive scan in my LG DVD player model 8680?
Nov 22, 2007 | LG DK 9411P DVD Player
PL-D2000 DVD Home theater System
Comments: To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region Ensure TV monitor is on so and set to display DVD. 1. Turn system completely off. 2. Turn on system. 3. Open tray. 4. Using remote press and hold the return button. 5. While holding the RETURN button, press and hold the DISPLAY button. 6. You will see something like this displayed on screen: VER 1006 TE 3210 7. Release DISPLAY and RETURN buttons simultaneously. 8. Press the ANGLE button. You will see WRITING REGION ID displayed. You can now play DVDs from any region. 0
May 27, 2007 | Teac PLD2000 System
Tv/dvd combo only plays dvd's in black and white
Finally figured this out. On your remote push tv menu until you get to function. You should automatically be under col.sys. change this to NTSC. Took me awhile to get remote to work here, ended up pushing in the middle of the red vol +,- bar on the right of the remote. Couldn't find the right button according to the directions on the screen. DVD is now in color!! If you are not already on the option to change col.sys, use the red channel up down bar on the left of the remote.
Feb 22, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
RCA DRC212N DVD Player Logo
122 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
