Question about NTI Ninja
My NTI Ninja has corrupted the files on my the private partition of my external drive. Is there any way that I can get my files back?
How can I conform that NTI is working? I can't see changes.
I presume that you are referring to a program produced by NTI, probably NTI Echo, which is a backup program. If so, then be aware that as it is a backup program, it will not delete data from your hard drive but, instead, make a second copy of it (thus the term backup). If what you want to do is use the drive for additional storage so as to free up space on your primary hard drive, then you do not need to use any software whatsoever. Just move the data from the C: drive to the new external hard drive and make it happen.
One suggestion, however: make sure to use directories (aka folders) to organize the files that you move to the external drive. The reason being that the root directory (such as C: or D:) has a limited amount of storage capacity, so just dumping files into the root will cause the hard drive to be "full" despite having plenty of storage capacity remaining. Besides, it will be easier to find the data that you desire if you have it more appropriately organized. ;-)
Sep 25, 2014 | Computers & Internet
Nti backup now error message during installation
Install the software before plugging the device in. You may have to uninstall first. Right - Click on the installation file and click ' Run as Administrator'
Dec 05, 2013 | Computers & Internet
No space on hard Drive but
Seems like a corrupt partitions. First run CHKDSK to check for corruption, then try to repair MFT.
Nov 11, 2013 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
Is there anyway to get data off a corrupt hard disc drive
Yes, usually the operating system is what corrupts and the data is typically intact. You will need the following.
  • Hiren Boot CD Here Download the ISO file and burn it to a CD from another computer
  • An External HDD
With your Hiren disc in the computer with a corrupt drive, boot to CD/DVD. You will get the Hiren Boot Menu, select boot to Mini XPThis will load a live Windows XP image. Plug in the external drive open up "My Computer" and navigate to your data on the C Drive. Copy it to the external drive.Now you can proceed to wipe out your corrupted install and copy your data back.
Oct 02, 2012 | Lenovo IdeaPad V570
Error message that says Drive is not accessible. The file or directory is corrupted and unreadable.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
How to recover the permanently deleted files from my 250gb verbatim external harddisc
you can recover deleted files from external hard drive with asoftech data recovery software, you can download the software from
Oct 08, 2010 | Verbatim VER95327 USB Hard Drive
My external harddisk - WD 320G(my passport essential) can not recoginze on Window 7. Please help to slove.
First check physical connections of hard disk to your cpu. Check in 'device manager' disk drives tab. If its found check in "disk management" in that drive which file system its showing. If it shows raw partition mean your file system is corrupted. It requires remove that partition and create a new partition.
for open device manager : start > run > devmgmt.msc
for disk management : start > run > diskmgmt.msc
Aug 04, 2010 | Western Digital 320GB MyBook External USB...
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
Computers & Internet Logo
35 people viewed this question
Top NTI Computers & Internet Experts
Tproverb
Level 1 Expert
Mari Criss
Mari Criss
Level 1 Expert
CruzSophia
CruzSophia
Level 1 Expert
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
