Question about Element Televison & Video
TV powers on...element screen comes on and then screen goes black
  • 38 Answers
If the tv is power on and having a sound the problem is only the heater supply of the picture tube...
Posted on Mar 12, 2011
5 Suggested Answers
rustym62
  • 201 Answers
SOURCE: TV is about 1 year old. Started yesterday having a
most times a black rectangle pops up when closed captioning is on. sometimes there will be gibberish in it sometimes not. See if you have button on remote labeled "CC" . Also if you have a cable or sat box make sure closed captioning is switched off there too.
Posted on Jan 23, 2010
SOURCE: samsung tv le37r8
Using a monitor
1..connect computer/media center to your monitor,
2 click on nvidia nview display settings,
3, select the current display tab and samsung,
4 then apply,
5,then when the confirmation box appears click yes within 15 seconds.
Using your samsung.
Attach a scart to your media centre, from your t.v with the p.c cable still attached, turn over using the source button until you can see a pc picture on your screen (EXT1or2), do steps 2 & 3 THEN move your cursor to the apply button (do not move the cursor from this position), press your source button till you get PC channel (which has no picture yet) then press your mouse button to apply, ( your picture will flicker on), and before the picture goes confirm with the yes button. You now have light! eureka :)
Posted on Jan 16, 2008
panchal643Ja
  • 243 Answers
SOURCE: tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
SuperTech-11
  • 1591 Answers
SOURCE: i have and olevia 26 in tv..when i try powering
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Cpacitors are less than a buck a piece typically if you order online from a place like www.digikey.com plus shipping, and they usually arrive next business day.
Posted on Jul 13, 2011
Why does the screen goes black?
Check with the place purchased about warranty service. or the manufacturer's website .
Jun 23, 2017 | Element Televison & Video
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
It has "V1.43 Pace PR150BNM SysCode Loader" Pace. Across the top of blue screen, what's up?
Element Electronics blue screen no signal Questions ... - Fixya
www.fixya.com > Forum > Tags > blue screen no signal
Blue screen with ''component 2'' in a box shows. Then it goes black.There is also a humming coming from the tv. I have unplugged everything from the tv, and ...
element tv problem - YouTube
? 2:26
https://www.youtube.com/watch?v=2FnqRRcQzNs
Feb 17, 2010 - Uploaded by pacman552sd1
... is a vid im attaching to my email to custamer support to try and fix my bad tv. ... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW ...
Dish Network - My element TV is saying "no signal". ' Directly
Jan 09, 2016 | Element Televison & Video
My tv turns on and shows the word element, then goes to a black screen, how do i fix that?
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 16, 2012 | Element Electronics Televison & Video
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
No picture just comes sound
sounds like the Backlight has failed, if you look closely at the screen you should be able to see the image changing, but as there is no back light there is no luminescense so it will appear black or grey, It is probably the backlight inverter or element that has failed, if this is within warrany organise with them to fix it for free,
Dec 22, 2006 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Televison & Video Logo
104 people viewed this question
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
