Question about Samsung Refrigerators
My samsung referigrator RT26M is not working at bottom window while freezer is working well
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
Freezer not working flashing -8
samsung unit are dual cool meaning as longer compressor don't fail refrigerator will work even if freezer fail and vice-verse. If freezer is not working and refrigerator must like you have defrost problem which is very common in Samsung unit, can be something as simple as a sensor or it can also be the heating element. also check the temp in the freezer it can also be the evaporator fan
Dec 20, 2014 | Samsung RF265AA Bottom Freezer French Door...
Why freezer part is not working on my samsung rb2055sl
The most common part to replace is the timer motor. It's usually located on the back bottom of fridge, It's a little thingy about 1 1/2 " in diameter. One screw will usually get it loose where you can take a look at it better to see if it's turning. It has a small window where you can see a little wheel turning.
Sep 05, 2014 | Samsung RF265AA Bottom Freezer French Door...
All the shelves have become brittle.
The bottom door bin for your Samsung is part number DA63-01263C. The next shelf up, called the middle guard, is part number DA63-01262A. The "facings" for the bottom two freezer drawers (also called freezer tray covers) are parts DA63-01653A and DA63-01652A. You may order these parts online at http://www.partstore.com/
Mar 05, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
Dec 11, 2008 | Samsung RS2630WW Side by Side Refrigerator
My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Jun 22, 2008 | Samsung RF265AA Bottom Freezer French Door...
There is a screw down foot in front of each forward wheel under the fridge. You can access this by looking under the front corners.
Dec 21, 2007 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
46 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
