There should be a mechanism in the door jamb near-to the seatbelt. If equipped, push on it while jerking seatbelt until it retracts. If not equipped, close door firmly while jerking seatbelt to activate retract.
There are a number of reasons why a car door won't open. First, make sure the car is unlocked. If it is, check the seatbelt. If your seat belt does not fully retract, it may be closed up inside the door of the car. Sometimes when this happens, the door closes with the seat belt positioned over the door's latching mechanism, causing everything to jam.
Read more: Reasons a Car Door Won't Open ' eHow.com http://www.ehow.com/way_5390808_reasons-car-door-wont-open.html#ixzz1tFeulJqO
------------------------------------------------------------------ godiag key programmer
the signal wire for the setbelt is broken in the rubber boot that is in the door jam. These wires are known to brake from being bent so many times from opening and closing the doors.
This is how I fixed my seatbelt problem.
If the running boards are out before start your vehicle, open door,go to your fuse box and pull the fuse. The back of the panel will tell you what each fuse is for and location. This'll keep them from retracting.
check all under dash fuses (both ends) with test light , some will not light tester at all , those just ignore , they are key on fuses , test only key off fuses , replace fuses as needed with same amperage rating , if not sure : consult owners manual
2000 Honda Odyssey the middle seat belt is broken. The seatbelt won't retract. The end of the belt does not come out but the entire seatbelt will come out of the hole. Any suggestions?
