Question about Dell Latitude D600 Notebook
My NIC configuration setting is off, how should i on this?
  • 29 Answers
2 things to check:
- Fn + F2
- Start --> Control Panel --> in classic view, click Network Connections. Make sure wireless network connection is enabled. If it is disabled, right click and enable.
Posted on Mar 12, 2011
  • Dell Master
  • 629 Answers
Not sure which NIC configuration you are referring to, but you can always open network connections in control panel to adjust the settings. reinstalling the driver may also help. if it is something else like wireless, it may help to clarify which configurationn you want to turn on.
Networking problem
You need to describe your problem further if you are you to get meaningful help.
Important things to look into are :
Mar 30, 2011 | Dell Latitude D600 Notebook
Network key for ot 800
How do I configure my NIC with a static IP for use with a SpeedTouch Home?If you are using an Alcatel SpeedTouch Home (without a router), a PPPoE client such as NTS, WinPoet, or RASPPPoE, and are experiencing stalls and freezes while surfing or connected, it may be that your NIC is not configured correctly. You must set a Static IP on your NIC. If you have it incorrectly set for "Obtain IP automatically" it will be looking for a DHCP server that does not exist. During the time the NIC is searching for the DHCP server you will experience stalls and freezes. An incorrect NIC settings will also cause the PC to take a longer time to boot up.
This FAQ has two sections:
Section 1 - NIC Properties for Windows95/98/ME
Section 2 - NIC Properties for Windows2000/XP
bred.gifStep 1
Click on Start ->Settings ->Control Panel ->Network
bred.gifStep 2
Once at the Network Window scroll down and look for the first entry in the box marked Internet Protocol (TCP/IP) that is associated with your hardware ethernet card (ignore dialup, AOL, and VPN type bindings). Select the correct Internet Protocol (TCP/IP) entry and click PROPERTIES.
Actual screen shots may vary
bred.gifStep 3
Select the IP ADDRESS tab. Select Use the following IP address and enter 10.0.0.1 and 255.255.255.0 into IP address and subnet mask fields respectively. Do not click on OK yet.
bred.gifStep 4
Select the GATEWAY tab. Enter 10.0.0.138 into New Gateway field and click on Add. Click OK.
bred.gifStep 5
Close all windows and restart the PC.
Section 2 - NIC Properties for Winows2000/XP
bred.gifStep 1
Click on START -> SETTINGS -> CONTROL PANEL -> NETWORK CONNECTIONS. Right click on Local Area Connection and select Properties
bred.gifStep 2
On the General tab highlight Internet Protocol (TCP/IP) and click PROPERTIES.
bred.gifStep 3
Select the GENERAL tab. Select Use the following IP address and enter 10.0.0.1, 255.255.255.0, and 10.0.0.138 into IP address, Subnet mask, and Default gateway fields respectively. Click OK.
bred.gifStep 4
Nov 11, 2010 | Alcatel Speed Touch Home Modem
Will any Wireless Adapters work without the PC's NIC?
Yes even without any NIC card installed on your computer , the wireless adapter will definitely work since its a different device that work for wireless connection and has nothing to do with your NIC card configuration.
May 15, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
Dell Power Edge 2600. It has an ERA nic but can't configure it?
The ERA is not like the more modern DRAC's ... it must be configured through the OS.
Feb 21, 2010 | Dell PowerEdge 2600 Server
How do we hook up ? internet/printer/network on a Sharp ARM 350
First off you need to make sure that the AR-M350 has a network port on the back of it (next to the parallel port). This model did not come with a NIC only the AR-M350N models did. If it does have a NIC port then you only need to plug in a patch cable to your network jack. As long as the machine is set to DHCP it will find an IP after you restart the copier. To configure a manual IP address you log in as key operator under system settings then navigate to Printer Settings - Network Settings.
Oct 15, 2009 | Office Equipment & Supplies
Network card not detecting in RHEL4 & 5
The solution proposed by user 'Solutions58' seems to be about windows box since he is talking about 'Device Manager'
RHEL4 or 5 detect compatible NIC cards during boot up process automatically. Sometimes NIC may be detected but may not work properly due to lack of proper driver (a.k.a Module - in Linux culture).
Do this -
1. First find out from HP's web site if NIC for your model has Linux support. You can also use Google to find appropriate driver for your NIC. If yes then you need to follow instructions that are provided in the INSATLL file that comes bundled with the driver.
2. Otherwise buy a $10 NIC card which has Linux support. Disable your onboard NIC through your computer's BIOS and boot it. Linux should detect your NIC right away.
3. Following command can help you in your quest
As root
# dmesg | grep eth (Will show your detected NIC)
# service network status (Will also show configured & active devices)
# ifconfig -a (Will also show your network devices and related info)
# system-config-network (will let you configure your NIC via GUI)
(This would be your best choice)
# system-config-newtowk-tui (Will give you a text base interface to configure your NIC)
Aug 05, 2009 | HP Computers & Internet
Emachine T3624 NIC Problem
Shut the computer off at the beginning of the bootup process look for the function key or keyboard button to get into the bios setup. Press that button and look in the settings to disable the onboard network adaptor.
Nov 27, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Disable onboard NIC
Onboard LAN can be disabled through the desktop board BIOS Setup Utility. The setting is located in the Advanced screen under Peripheral Configuration.
Apr 27, 2007 | FIC Samba SM-1845 (SM1845GV) Barebone
Dell Latitude D600 Notebook Logo
Alun Cox
