I am attempting to reconnect my home stereo but do not see a cord or wire to connect the bass to the system. is there supposed to be a connective cord for the bass speaker? it is a 530 watt MHCGX99 model number. thanks
    Master:
  • 346 Answers
Hi from one Lakers fan to another 8^) - Yes you do. You need a cable to plug into the
sub-woofer out port on the receiver to the connection on your sub-woofer.
If you can't find the original cable, get a short (three ft.) standard stereo cable (one that has two cables, a white and red). Just plug one of the cables (the red or the white but it has to be the same color on both connections) into the receiver and the sub-woofer.
You'll be ready to pump up the bass.
Enjoy and thank you for using Fix Ya
Mikeywaf
Posted on Mar 12, 2011
I have a Th-C50 home theater and lost my subwoofer system cord, can I use a regular s-cord to make that connection? or is it useless with out the cord?? Please help!
Yes you can use any 2-core cable to carry the bass signal to the subwoofer. As the bass speaker cone is the largest cone in your speaker set I would recommend a good quality cable of decent gauge (thickness) to carry the bass signal.
You just need to make sure you have the right connectors for the amp and sub and make sure you connect positive to positive and negative to negative.
Hope this helps,
Chris
Mar 02, 2011 | JVC TH-C50 System
Noise/No Bass in Delco Systems stereo
You have a possible fault in your wiring of the speakers, the Phases of the speakers are crossed over resulting in cancelling of the low frequency- bass frequency. Hence please reconnect the speakers front and rear with the positive/ negative to the corresponding positive and negative of the speakers.If you are unable to fix the marking of the polarity use 1.5 Volt cell to connect to the speakers , if the speaker moves up the terminal on the positve of battery is positive. reconnect and test with a good bass song for result. Helpful. Good day
Jul 05, 2010 | Car Audio & Video
Connecting ipod to bose system
Look at the back of your 3-2-1 to see if the auxillary is a single or dual output. You will need that information when you go to Radio Shack, or you can also get at the Apple store, a connector from Gigaware that connects to the ipod. It was only $15-$20,
Jan 04, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Blu-ray + bose 3-2-1 system connection?
Connect an HDMI cord from the bluray player to a free input on your HDTV. Then connect the standard WHITE/RED stereo cable from the bluray player into the AUX input in the back of your 3-2-1 system and voila!
You may need to check the configuration of your bluray player to make sure that is outputting stereo audio, for this please refer to the player's user manual. Other than that, you should be alright.
Dec 07, 2008 | Bose 3·2·1 II System
SPEAKER WIRE CONNECTORS
You need 5 Cord (wires) Connection to attache all speakers.
You can have all 5 cords in one package or each cord individually at Sony Accessories.
Please write model number DAV-FR1 in search box to get result on above web page.
Details of wires required.
182724411 1 BAG = 5 CORDS approx $43
179146811 CORD, CONNECTION approx $10.30
Nov 10, 2008 | Sony DAV-FC8 System
Bass control stopped working
on rockford amps, the bass control knob needs to be connected to get the maximum output (+18 db gain i believe). If you did this to the power wires, then yes, you may have at least damaged the bass control knob. Try replacing this to see if you get all of your gain back. If not, then you have damaged something inside the amp...maybe a capacitor or power supply inside. If that's the case, you'll need to get the amp looked at by an electronics repair technician or local stereo shop.
Aug 10, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Ipod sound through home entertainment
get a stereo to phono cord.
connect the stereo pin to the ipod (ear pin) and connect the phono cord the the input section of the home theatre.
after all this just put on everything and start the music on the ipod.
if it does not come just increase the volume of your home theatre.
hope to hear favourably from u.
thank u and good luck.
have a nice day.
Jul 05, 2008 | Apple Logitech Inc MM50 Portable Speakers...
The Surround Sound sub-woofer doesn't play bass likes it's supposed to, but the bass plays out of the of the left speaker. What's the problem and how should i solve the problem?
check the setting of your sub and confirm that it is on-check cable of sub and confirm it is connected firmly.-disconnect power cord and reconnect it again.
Jun 26, 2008 | Panasonic Audio Players & Recorders
Will not power up
Your have to open the system removing the six screws on the bottom. Once the cover is off you might want to remove the am/fm connetion to give your self more room. You just unplug it from the board by gently pulling on the white connecting plastic and not the wire. Pull the am/fm board toward the front a bit and lift up. You shold see three shinny metal wires per say. and the one you want to check is the one that looks like it's connecting straight into the display screen. Notice two seem to connect towards the front. You want the one that is straight forward. This was the connection that had come undone on my system and was causing the no power up just the "BOSE 3-2-1" message.
If you need further advise on this procedure e-mail me at
tonyandne4ever@yahoo.com
May 02, 2008 | Bose 3 2 1 GSX System
Open Questions:
73 people viewed this question
 Grubhead
Grubhead
