Question about Arris Vanguard 340 Router
How to reset for factory default of vanguard 340 ?
  • 3 Answers
Like most gadjets... look for a pinhole (either on the bottom or the back) labeled reset. Use a pen or paperclip to press the button while the unit is on. Hold and press for a few moments. You may also need to restart the unit.
Posted on Mar 13, 2011
How do you reprogram a Uniden Bearcat BC 340 CRS
Uniden BC340CRS Owner Manual
Resetting the Scanner (Clearing all Memories)
To reset the scanner to factory defaults, turn off the scanner. Then, while holding down 2, 9, and HOLD, turn on the scanner. All scanner memory contents are erased.
May 14, 2016 | Uniden Radio Communications
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
How to reset my 2600c-2, i forgot the code
how to reset my nokia 2600c-2
Type :RM-340
Code :0576463
IMEI :355208/03/031266/4
made in INDIA
CE 0434
Feb 28, 2011 | Cell Phones
Ok i have a belkin wireles router num f5d8236-a v2 and when i first got it the modem light was flashing and now it will not detect the modem at all
I would do a factory reset of the router for the manual go to this website http://www.belkin.com/support/ Choose routers, then in the next page, in the first Dropdown "N", next dropdown, your model
this should be a direct link http://en-us-support.belkin.com/app/product/detail/p/340/session/L3NpZC9ndm9QdExYag%3D%3D
Page 10 of the manual
The “Reset” button is used in rare cases when the Router may function
improperly. Resetting the Router will restore the Router’s normal
operation while maintaining the programmed settings. You can also
restore the factory default settings by using the “Reset” button. Use the
restore option in instances where you may have forgotten your custom
password.
i. Resetting the Router
Push and release the “Reset” button. The lights on the Router will
momentarily flash. The “Power/Ready” light will begin to blink. When
the “Power/Ready” light becomes solid again, the reset is complete.
ii. Restoring the Factory Defaults
Press and hold the “Reset” button for at least 10 seconds, then
release it. The lights on the Router will momentarily flash. The
“Power/Ready” light will begin to blink. When the “Power/Ready”
light becomes solid again, the restore is complete.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I need the line command set to configurate a Motorola Vanguard 6455, thank a lot...
Open command propmt, type there ipconfig and look for default gateway. Take note of the default gateway numbers and type that on the address bar of your IE browser. There you can setup the device.
Jun 09, 2009 | Arris Vanguard 6455 Router
Blurry images on camera
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 22, 2009 | Olympus FE-340 Digital Camera
Vanguard 6455: double configuration.
when u reboot your router, at POST type ZAP command.. by this you will reset your password as well as your configuration.
try this and let me know ... wht happen??????
Jan 28, 2009 | Arris Vanguard 6455 Router
Vanguard 6455 router lost password
in my experience, any router where you cannot access it, you will have to do a factory reset. Generally there is the small paperclip size button in the back that you press and hold for 10 seconds while the router is on. after that, you release and unplug the router. Press the small button, plug in the router, and hold it for about 20 seconds. Sadly, I have found this my most common and best answer...
Dec 19, 2008 | Arris Vanguard 6455 Router
How to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Jul 22, 2008 | Cisco Aironet 340 Wireless Bridge
Arris Vanguard 340 Router Logo
118 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
