I have Samsung ML-1660 printer it turns off by itself . it is very hard to print some times i turns off while printing half the paper dont know how to solve the problm
flopez
  • 161 Answers
SOURCE: Samsung ML-1710P Printer Problem
Most probably you took one of the paper sensors out of place. Any printer technician can happily put it back.
Posted on Sep 22, 2007
  • 13 Answers
SOURCE: laser printer ml 2010, paper pull in problems
I lifted up the front of the machine a couple of inches, using a cardboard box.
The paper now feeds downhill slightly.
It works well. Worked on my CLP-300 too.
woodhouser
Posted on Mar 08, 2009
SOURCE: samsung ml-1610 pulls in paper only half way then stops
Reinstall driver, turn off and on again. No official solution, though. It just worked for me.
Posted on Mar 19, 2009
CompuFirm
  • 89 Answers
SOURCE: Samsung CLP-315 prints half a page and then stops
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
Posted on May 26, 2009
  • 220 Answers
SOURCE: samsung ml-1710 printer continues to jam paper;
pickup roller and seperaion pad req changing
Posted on Jun 22, 2009
How do I cancel a print job on the Samsung ML 1660 series?
cancel the current job by pressing power button. This is a capture shot of the ML 1660 series user's guide.
Oct 06, 2017 | Samsung Office Equipment & Supplies
There is a paper jam inside the printer and i dont know where
For some paper jam like this it will be better if you blow air inside your printer and make sure everything is clean and not even a small piece of paper is causing the problem. SO better do check again the inside of the printer and use a flashlight for you to see everything.
Feb 07, 2013 | Samsung ML-1660 Monochrome Laser Printer...
Creased paper
If that happened to me I'd try printing a dozen - 100, if needed - pure blank white pages in an effort to clear any other problem without wasting toner.
Nov 05, 2017 | Samsung Office Equipment & Supplies
My ML 1660 Laser Printer is printing documents with lines (or smudges) on the left side of the paper. How can I fix this?
Dear
Check the toner carts. If you are using a refilled cart. replace the Drum unit.
Some times at the coastal area and the printer not used a prolonged time moisture causes this problem, however rubbing with a dry cotton cloth on the OPc drum may recover.
Thanks.
Dec 05, 2010 | Samsung ML-1640 Monochrome Laser Printer
I have problems with the printing, samsung ML 1660. The printer expected to turn the sheet for start, after the first print. If I press the button, it starts, but .... the printer has not duplex. What must...
I have a bad printing result with my ml 1660 toner cartridge. the printing result shows lines on the sides of the paper. What must i do? Please help me..
Nov 01, 2010 | Office Equipment & Supplies
Red light stays on, and nothing prints. won't recogonize paper in tray???
Depending on how long you have had this , it might be time for a new one. If its still under warranty, rather send it back as it could be a problem inside.
First do a couple of test.
Turn the Printer off and back on?
Reinstall the software for the printer?
Paper **** under the toner drum? Dont touch the green drum!!!
Pull toner out and reinsert
On the top side above the toner were the paper feed's after printing. Is there a paper jam?
Did you replace the toner with a "compatible" toner? If so the printer does not recognize the cartridge thus another reason for the red light?
if you have had your ML 2510 for longer than 2 years and 4 Toners. This is a good time to invest in another ML 2510 Printer. They are cheap and dont break up the bank's money printer to get.
I hope you find help with this.
AJ
Dec 07, 2009 | Samsung ML-2510 Laser Printer
Samsung ml-1610 pulls in paper only half way then stops and red light turns on. I tried to restart printer, replace papers, put only one page, put many pages... nothing works.
dear,
pl swithch of your printer and remove printer cartridge from printer. and open rear side of door of printer and remove your page gently
after remove page see carefully paper is jamed or not.
after swithch on.
check with print.
Feb 28, 2009 | Samsung ML 1610 Laser Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
k24674
jasbo
jasbo
