Driver for my lan conection - Computers & Internet
    Master:
  • 525 Answers
Go to your pc manufactureers website. they have all the drivers. You may have to get it from a computer that has internet access if you dont have it on your machine. In that case you would have to burn the file onto a disc or use a usb flash drive.
Posted on Mar 13, 2011
How many pcs can you conect to netgear09 router
Yes you can, connect one of the LAN ports from the router to a LAN hub, Then you have 3 LAN ports on the router and the other LAN ports are on the LAN hub.
Sep 27, 2012 | Computers & Internet
Problem with lan in dell ispiron 6400. When I put in lan wire it shows that cable is not conected. Cable is ok, I tried few. When I look on the conection window sometimes it flashes for less than one...
Inspect the pins inside the network connector. They have to be even and stright. Sometimes people put there a phone cord connector and it bends pins 1, 2, 7 and 8. To recover use a needle with slightly bended tip. Hook the pin with the bended tip and pul until strightened.
Apr 08, 2012 | Dell Inspiron 6400 Notebook
Why Thinkpad T23 2647 4MP can't conect net after installed windows XP?
I do not use an automatic driver detection program, because they have a tendency to install the wrong drivers.
I look in Device Manager, and use the driver that matches THAT device, the O/S used, and is the newest version, (Date), with all the bugs worked out from an older version.
For your laptop that would be;
Ethernet Driver for Intel PRO/100 VE LAN that is the 49675 version, and has the date of November 8, 2002,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS002672
Regards,
joecoolvette
Jan 28, 2012 | IBM ThinkPad T23 2647 Notebook
When installing the disk it says the ethernet cable is not conected when it is
Connect the LAN cable from the D-Link to the LAN port on your computer. If you have alreadt done this and you get this error message then it is possible the LAN card driver has not been installed.
I suggest you install or reinstall the LAN card driver before running the D-Link installation disk.
Jun 20, 2011 | D-Link DIR-600 Router
My Samsung printer is conected on other computer,and not printing
try to reinstall printer driver.
Be sure printer IP adres is correct.
Good Luck!
Jun 21, 2010 | Samsung ML-2251NP Laser Printer
No LAN conection displayed in network connections
check that proper driver is installed, in the device manager that shows excmlatory mark that indicates proper driver not been installed, update the driver it will works
Mar 22, 2009 | HP Pavilion a6547c Refurbished AMD Desktop...
LAN not conecting
remove ur lan card and clean it and install it
Jan 21, 2009 | Acer 91.AB370.001 Network Adapter
Wireless internet not working contacted perlico and they said that lan port was not open
try pressing start, control panel, network and internet conections, network conections this should show your lan page then press on the lan you need to conect then it should be conect or bridge conections
Nov 04, 2008 | Siemens Computers & Internet
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
