Question about Cameras
Error "open shutter"
  • 38 Answers
Please check the shutter inside because thats is making desalign...consult the expert..
Posted on Mar 12, 2011
Oki c8600 registration error 3
Registration Error 3
When a color registration error is detected with coarse
adjustment, or with the main-scan line adjustment.
PU firmware does not notify this warning to CU firmware
at the time of Shipping Mode. Therefore, this status
does not occur in a user environment.
n
2 = Yellow
3 = Magenta
4 = Cyan
Dens Shutter Error 2
DENS SHUTTER ERR
Check 3: Check to see whether the sensor shutter opens and closes normally, by the
MOTOR & CLUTCH TEST of the self-diagnostic function. If the shutter operates
imperfectly, replace the shutter unit.
May 06, 2014 | Oki Electric Industry C8600n Led Printer
"Error. Press shutter release button
hiit is not easy to tell what exact problem. It has quite of causes in your case. But I can only tell most common cause that it is sequence unit fail. It could also other like shutter fail, mirror box mech fail, motor fail, control pcb fail, and so on...etc...I recommended you bring to your local service place or Nikon service center which is helpful to you.
Jun 04, 2011 | Nikon D3100 Digital Camera
When I set my Nikon D3100 on and it is in auto mode, in the screen comes message " Error. Push the trigger again". And when I push it appears again and again. I Can't take any pictures at the...
hiyou first distinguish what it cause. I suggest separate body and lens. Please enable without memory card.( remove memory card), Set to Bulb speed on Mode. Press hold and see front of camera, you should see mirror up and shutter curtain fully open inside ccd image sensor surface. Release shutter button. See what error message come out.
Jun 03, 2011 | Nikon D3100 Digital Camera
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
Apr 18, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
I turned it on and it said "Error. Press shutter release button again." I did and it isn't doing anything.
Your shutter is damaged. Contact Nikon customer support, as it is probably still under warranty.
Mar 03, 2011 | Nikon D3100 Digital Camera
My Nikon D60 "Error. press shutter release button
Hi
The error is with the shutter release button and the unit has to be taken apart....Get it repaired by Nikon it is a common problem with these units.
Thanks for using FixYa
Have a Nice Day
Jan 25, 2011 | Nikon D60 Digital Camera
HI. Every I attempt to take a picture with my cam, I get a "Error 01" message. Please advise. Thank you
Err 01: LENS COMMUNICATION DESCRIPTION: This error occurs in the following conditions: When electronic communication with the lens cannot be established, after the EOS D300D is powered ON or when the shutter button is pressed halfway. When the lens diaphragm cannot be controlled during shutter release.
REMEDIAL MEASURE: Clean the electronic contacts on the lens with a clean, soft, dry cloth and check the mount interface switch on the body's lens mount for dirt or other damage. If this does not solve the problem, try another Canon EF lens or have the EOS EOS D300D examined by a qualified service technician. This error is similar to Error 84 on the D30.
rate me on this one...
thanks!
May 09, 2009 | Canon EOS 40D Digital Camera
Error 04
This is either shutter flexiboard problem ( shutter not opening and closing ) or is caused by zooming problem . In either case it is not economical to repair . You will be quoted +- $ 150 to have it sorted out.
Sep 16, 2007 | Photography
Cameras Logo
11 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
