Question about Panasonic Microwave Ovens
MY MICROWAVE WILL RUN FOR ABOUT TWO SECONDS ANND CUTS OFF I UNPLUGED IT AND WHEN IT COMES BACK ON IT SAYS TO REFER TO MANUAL WHICH I CANNOT FIND.
  • 876 Answers
You should be able to download a manual from the manufacturers website. You will need your model #.
Posted on Aug 01, 2008
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
Panasonic Microwave NNA883 cuts out after 20 seconds.
You need to replace the diode. Scratch that. The voltage let alone the radiation could kill you. Call a technician. If it is a table top unit, buy a new one. It will be cheaper,
Aug 27, 2012 | Misc - MFG Microwave Ovens
My EWave Microwave cuts off before time is done.
you have problem with a) power diode b) high voltage capacitor short, c) Magnetron defective.
you must consult to qualified tech for repair. or go to some repair shop TV for fix it.
God bless you
Jul 10, 2012 | Microwave Ovens
I have a Panasonic microwave convection that runs for 2 or 3 seconds, then cuts off. It doesn't matter what setting or length of time you program into it, it will run a couple of seconds and shut down. Is...
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Sep 08, 2010 | Panasonic NN-C994S Convection/Microwave...
When start Microwave after a couple seconds it stops and asks you to set the clock again.
The magnetron on most all microwave ovens is tied to the microprocessor that drives the display and the input from the keypad.
Check you manual to see if it comes with a self-diagnostic (higher-end microwaves from Panasonic, LG and Jenn-Air come with them) and run it (normally kicked off by a keypad sequence).
If unplugging the microwave and plugging it back in after about 15-20 seconds doesn't correct the problem, then I'd get it serviced if under warranty. Microprocessor will need to be replaced most likely. If not covered under warranty then you're looking at out-of-pocket repair or replacement.
Jun 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Magnetron replaced. Message: "refer to ops instructions." ???
If it was done by a repair place just take it back and read the riot act to them. Thats NOT acceptable. If you did it yourself, I would guess it wasn't just the magnetron, probably high power diode and other things too.
Feb 20, 2010 | Panasonic NN-P294WF Microwave Oven
Cuts off know heat
Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Nov 13, 2008 | Panasonic NN-P794SF Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Microwave cuts out after 23 secs
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Dec 15, 2007 | Panasonic NN-S550WF Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
