Question about Dryers
Dryer stopped spinning. Only buzzes when i turn the start knob.
    Problem Solver:
  • 5 Answers
Without any other information to go on, I would just guess that the belt that connects the dryer drum to the motor has either broken or slipped off.
It could also be something as simple as the lint catcher is clogged and the dryer has overheated. Make sure the lint filter is clean and that the dryer duct is not clogged on the inside behind the dryer or on the outside at the vent. This can sometimes happen...you might have to remove the vent outside and dig inside with your hand or with some type of object to clear it out.
If it is the belt: This is something that can be repaired by a service technician (or by a homeowner if you are "handy"). If you are wanting to fix it yourself do the following: 1. See if you have the owners manual and if it has a parts list. 2. if you don't have it, try to find it online and print it out 3. DISCONNECT THE DRYER FROM THE POWER!!!!! And then disconnect the dryer vent hose/line 4. Pull it out from the wall and look at the back of it. There is probably a panel held on by some screws or bolts. 5. Remove the panel to get a look at the dryer motor and drum. 6. You should be able to see if the belt is broken or slipped off. 7. If it's slipped off you can try to put it back on. This may work only temporarily because it's already slipped once, it's probably worn out and will do it again. 8. You can use the parts list from the owner's manual to purchase a new belt and then install it yourself or have a trained technician do it for you.
Posted on Mar 12, 2011
LG DRYER TURNS ON BUT JUST BUZZES. SPIN THE DRUM AND PRESS START AND IT STARTS WORKING BUT ONLY TIL YOU STOP IT - THEN DRUM WILL NOT TUEN TIL YOU SPIN IT AND PRESS START
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 06, 2011 | Dryers
I turn the start knob and it just makes a buzzing sound
heatman101
Jun 06, 2010 | GE DBSR453EBWW Electric Dryer
Buzzing noise when i turn the timer switch
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Start switch does not work properly
The start switch is stuck closed. Replace the start button switch.
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer just stopped working. Turned knob to desired time and pushed start, nothing happens. When knob is on OFF position and I push the start button, it makes the regular BUZZ sound - times up, clothes...
Remove and inspect the timer knob for a crack or missing tension clamp.
Carefully place it back on the timer shaft while paying attention to the (D) shape in the knob and the shaft.
If they are aligned correctly notice where the position arrow is pointing, ie; off---run--etc.
You may well need a new knob.
Feb 21, 2009 | Dryers
Dryer will not start
Hello jslovik,
Welcome
You said, When you turn the knob a buzzing sound starts but that's it. The Buzzing continues as long as the start button is turned. Dryer is only 2 years old. Any help is very appreciated.
It sounds like the starting switch is bad!
10 134398300 Switch,start ,turn type In-Stock $ 11.29It appears in the diagram at the page below in diagram # 10
http://www.pcappliancerepair.com/model-display.php
If you do not know to diagnose this or repair it, please call an authorized tech.
Let me know what you do and how it goes for you?
Huuum
Believed I solved your question.Happy to have been of assistance.
Please remember to leave a rating.
Sep 19, 2008 | Frigidaire FGQ332ES Gas Dryer
Dryers Logo
555 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
