Question about Car Audio & Video
The 30A fuse always blows each time i replace it
  • 10,421 Answers
Please the problem on your system. If nothing problem there, please install a bit bigger fuse.
Regards
Posted on Mar 12, 2011
04' GMC Sierra quadrasteer, trec fuse 30a blows when trying to engage 4wd. I replace fuse, start truck and 4wd auto is lit up but if I press 2h, 4h, or 4 low it blows. What should I do or look for?
Wild guess here, had a similar problem on my 2000 4x4 blazer, has an electric motor on transfure case to swith it into 2h, 4h, and 4l, would blow the fuse every time when switching, did is to replace the motor. Just confirm your fuse that is blowing feeds that.
Oct 21, 2016 | 2004 GMC Sierra
My 2004 Pontiac Grand Prix gt keeps blowing the 30a fuse for the blower motor resistor wondering why it keeps blowing after replacing the resistor I've went through 4 of these fuses
Possible blower motor is defective pulling excessive amperages causing fuse to blow continuously regardless if its still operable.
Aug 18, 2016 | Pontiac Cars & Trucks
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Starter fuse blows
somethings shorting out, use a multimeter to diagnose where its coming from, hope this helps
Feb 22, 2014 | kawasaki ZX-12R Motorcycles
Windshield wiper washer switch , the fuse keeps blowing 20a it goes about 5 times and then blows the fuse i put a 30a fuse in and it bypasses and it wont switch off / on
Do not put a larger amperage fuse in. you run the risk of the wiring over heating and starting an electrical fire. More than likely the wiper motor is starting to go bad and is drawing an unusually large amount of current which causes the fuse to blow. Replace the wiper motor.
Oct 08, 2010 | 1996 Toyota Camry
Wiper fuse always blowing on ford 97 éconoline E-250.The wiper works for 2 sec and then the fuse pops.I did put a 30A like the old one. Thanks Terry
The wiper motor is drawing too much current. Winding could be shorting out, or there could be someting binding the wipers and/or linkage putting too much load on the motor.
Charlie
Aug 14, 2009 | Ford E-250 Cars & Trucks
My saturn l300 keeps blowing the #2 cooling fan fuse 30a
wiring may be shorting to a ground somewhere check wiring harness and connectors for a ground fault!!swampratt200!!AAAEE!!!
Jul 21, 2009 | 2002 Saturn Sl
Clio 182 2005 Coil? Fuse blowing regular (30a blade under bonnet)
How do u know that the engine is not firing? What about the housing cover where the fuse is being housed? There is ususally a schematic diagram for the fuses there or, at the back of it. There u will know the type of fuse that is always being blown. If any queries, u should probably check an auto electrician
Jan 07, 2009 | 2005 Renault 181
30a fuse fule system keeps blowing when starting car
Bad Fuel pump or electrical short in fuel pump wiring harness. Good Luck get back to me if you need help.
Dec 16, 2008 | 1983 Toyota Corolla Deluxe
1994 toyota corolla blowing AM2 30A fuse under the hood
On top of the cover of the fuses it will tell you what that fuse was for. Odds are whatever it is, is shorting out and will need to be replaced.
Dec 12, 2008 | 1994 Toyota Corolla
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
