Question about Garmin GPS
The tip on my Nuvi 260 W power cable came off (unbeknown to me) and is gone. Does the company replace this if the warranty has expired?
  • 1,514 Answers
You won't be able to buy the tip only but you can either buy a complete charger/cable from https://buy.garmin.com/shop/shop.do?pID=63951
or you can buy the same type of plug in most car accessory shops and simply take the tip off it for your car charger. To remove the tip you unscrew a ring near the end of the plug.
Posted on Mar 12, 2011
Computer doesn't find the garmin nuvi 260 gps
Download and install the usb drivers from the Garmin site.
Oct 01, 2016 | Garmin Nuvi 250w 255 255w 260 300
Garmin gps doesn't work when charging with cigarette charger. Instead of the GPS to Navigate it rather shows like there's a data transfer.
The proper vehicle power cables for the Garmin nuvi 260 are part numbers 010-10723-06 or 010-11478-03.
The use of improper cables will cause the nuvi to go into mass storage.
You may also want to contact Garmin Support for assistance.
http://www.garmin.com/us/support/contact
Sep 23, 2011 | Garmin nuvi 260 Car GPS Receiver
The LCD Blinks 10 times Need the service manual or tip on what has gone wrong. Power supply is generating 5v
I had a similar problem with my 42 in Philips LCD HDTV. Your power supply should be putting out more than 5 volts
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV(warranty was expired ofcourse) and found four bulged capacitors. Many electronic companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Here are some options . 1. Have it fixed by a professional 2. Dig into your TV, find PSB, Check for faultycaps. If you find some(bulged orleaking) bad caps replace the entire board 3. Remove and then replace individual faultycaps. This takes some solderingskill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. Hope this helps
Dec 10, 2010 | Televison & Video
Orange ring
Okay here are a few ways that might fix the Xbox 360.
  1. Turn off the Xbox 360, wait 5 minutes, plug it back in and see if the error is gone.
  2. Unplug both the AV (audio and video) cables and the power cables from the Xbox 360 and wall. Wait a few minutes, and replug everything in and see if the error is gone.
  3. Take your hard drive out of the Xbox 360 and start the console and see if the error is gone. If the error is gone, turn the Xbox 360 back off and replace the hard drive. Then check if the error is once again gone.
If none of the above steps worked, then your going to have to spend some money to get your Xbox 360 back and running.
  1. If your warranty hasn't expired, then you can send it to Microsoft and they will fix it for free.
  2. If your warranty has expired, then you can still send it to Microsoft, but it will cost you about $150.
  3. If you don't want to spend the 150 you can spend a little bit of money and buy a guide to replacing it yourself on Ebay and such. If you do try and do it yourself remember that once you open the Xbox 360 the warranty voids, so if you still have a warranty send it to Microsoft.
Hope this helps!
-Marcus Turtle
Jul 18, 2010 | Microsoft Xbox 360 Console
The USB port on the NUVI 260 is loose and will not charge
You will not be able to refasten it yourself. This is a surface mount part and you need a very small tip soldering iron to fix it, plus you ned to know how to modify it so it wont break again. Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 19, 2009 | Garmin GPS
My Garmin nuvi 260 is only 6 months old and it can
First make sure you have the latest software in it.
If it does try a Master Reset.
Lastly, unless you're in a strange location with poor reception. Take it back. Or, it's still under warranty.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on your nuvi 260 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Aug 04, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Nuvi 260 won't turn on at all.
Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
Jun 13, 2009 | Garmin nuvi 260W GPS Receiver
I have got a nuvi 260 and it wont come on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi 260 - how to activate text to speech
Make sure the voice you have selected has the letters TTS next to it.
Feb 28, 2009 | Garmin nuvi 260W GPS Receiver
Display problems with nuvi 260
You may have to send in for service. A bad screen normally is not a good sign. Sorry.
If you are sure that the updates have been downloaded your only other option is:
Trying a full master reset:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 260 series device: Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  6. Touch Yes
Feb 19, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
GPS Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
