Question about Mitsubishi LVP-X300 Multimedia Projector
How do i check the lamp life on the lvp-x300? how do i check the filters for dust?
For lamp life time, locate the UP, DOWN, and ENTER buttons on the keypad on the projector itself (not the remote) and press all three at the same time. The manual says you may get up to 2000 hrs., but we had to change ours at our church after 681 hrs., it was getting dim. There are filters on the bottom and front of the unit--find them and clean them!
Posted on Mar 27, 2011
Why will my mitsubishi lvp x300 projector only project a blue screen when I turn it on?
Blue is probably the default "no signal" screen. It means that the projector is getting no signal.
Sep 06, 2014 | Mitsubishi LVP-X300 Multimedia Projector
Why will my mitsubishi lvp-x300 projector only project a solid, blue screen?
Blue is probably the default "no signal" screen. It means that the projector is getting no signal..
Image Color problem
Yes. and look at the color wheel for a residue build up too. Use alcohol to clean it with a cloth that will not leave lint behind.
Jan 06, 2014 | Mitsubishi LVP-X300 Multimedia Projector
Red light labled LAMP stays on and I have no display of picture from projector
there is a problem with the lamp, hence why it will not switch on. Replace the lamp
Mar 31, 2011 | Mitsubishi LVP-X300 Multimedia Projector
Fan in ventilation didn't work and power lamp steady red,lamp red and Temp lamp binking red
Very likely the airvent is block or the timer for the airvent cleaning is max. See manual how to clean air vent filter and reset the timer after cleaning it
Aug 08, 2010 | Mitsubishi LVP-X390 Multimedia Projector
Greenish/Yellow spot
Sounds like a scorch mark on the polerising filter, this can only be replaced by an engineer cost around £70 ($150).
Marc Engineer
Apr 05, 2009 | Mitsubishi LVP-X300 Multimedia Projector
Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Shuttle83
Nov 20, 2008 | Mitsubishi LVP-X80U Multimedia Projector
I have a LVP-HC3000 DLP projector. I bought it new, I use it for sports and movies. It is 2.5 years old but it has <1500 hours on it. I do run it in "brightest" mode as do not have great...
the bulbs arent hard to change but run about 100.00 have you checked the filter on it to see if it needs cleaned> its either on the back ot the side of the machine.i have one here too that i use and never an issue with it
Oct 15, 2008 | Mitsubishi Televison & Video
Projector won't turn on
Have you checked the user manual to find out what this "error message" means?
You may need to replace the lamp.
Jan 03, 2008 | Mitsubishi LVP-X80U Multimedia Projector
Mitsubishi LVP-X300 Multimedia Projector Logo
187 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
