Question about LG Televison & Video
I have 2 LG Televisions and both turn on when i use either remote can i change the frequency of one remote
  • 1,591 Answers
Not really.
Here's a suggestion though...if there's one tv on the right and one on the left, make a small cardboard "divider". bend a thin piece of cardboard into an L shape so that one side lays flat on the tv panel, and and the other points right at you. Put the divider on the right hand side of the IR receiver of the TV on the left, and vice/versa for the TV on the right.
In a worst case scenario, you may hove to practically build a small tube around the IR receiver on the TV so that you practically have to be in front of it to use the remote (the smaller the tube, the less sensative it will be to the other remote. the deeper it is affects this too)
Experiment with what works best for your specific layout.
There used to be a time where you could get ultraviolet emitter/detector pairs, and I'd tell you to go ultraviolet on one set, but at the moment, this is the best I can suggest.
Something that MAY work (although I have less faith in this) is to experiment with different shades of red gels (light filters) matching up the same shade of red to each remote and TV. IE - cut a tiny strip of the shade-1 and place it over the transmitting LED of one transmitter, and likewise on the corresponding TV. This may limit the amount of light that gets through from each remote to each TV enough that only the remote for it's corresponding TV works.
And finally, this one can take some experimenting but it works like the building of a tube.
IF there is a way (without breaking boards etc) to move the IR receiver deeper into the TV, you will eventually find that ideal depth where it only responds to a remote directly in front of it, or at least stops responding to the other remote.
I have in the past suggested the tube method on the remote but inevitably people kept breaking off whatever was attached to the remote...but if you can move the transmitter diode back into the casing (again without breaking anything) the remote will be much more directional and less likely to control anything that it's not being pointed right at.
Posted on Mar 12, 2011
2 LG TVs and the remotes are both on the same frequency, how to change one please?
Doesn't work, I'm forced to use my hand to shield one or the other TV's at my place.
Jan 14, 2018 | LG Televison & Video
Grundig how to
Never set remotes beside each other and leave the room. You never know what they might do when you not looking.
Actually, unfortunately if both remotes are using the same frequency for some options there is not a whole lot you can do to change the remotes themselves.
What you can do: block (lay something in front of) the stereos remote sensor location. Or turn the stereo it's self 90 degrees. This pretty much makes using the stereo's remote a pain, but you'll change the TV more often.
Jun 13, 2014 | Televison & Video
I have 2 Vizio tvs with different remotes. But one remote will turn both tvs on and also change them. I don't want this to happen, can you help me?
There is nothing you can do about this. The remotes are using the same Infrared frequency, and this will cause both tv's to change at the same time when pressing buttons. You would have to walk right up to the reciever on the tv to change just one tv. This happens with any equipment that uses the same IR frequency
Mar 01, 2011 | Televison & Video
Which code should I input in a Grundig Universal 1 to seven remote control with an LG 20LC1RB TV
u will want to look through the manual that came with the universal remote control and find the make in there if for some reason it is not u can use the manual entry process which involves holding a few buttons and than scrolling through the frequencies until the tv either turns on or shuts off and than locking it in
Aug 20, 2010 | Televison & Video
Remote control signal
check battery contacts in remote..dirty,,loose,bat needs changing
Jul 07, 2010 | LG 42PJ350 42 in. TV
I HAVE 21 INCH LG FLATRON TV CHANNELS CHANGE AUTOMATICALLY, VOLUME CHANGE AUTOMATICALLY WITHOUT DOING IT FROM REMOTE
It is possible that there is other equipment which uses a similar frequency, this can be a cordless phone or a gate remote or other device capable of transmitting frequency
Mar 09, 2009 | Televison & Video
WE LIVE IN A CONDO AND SOMEONE IN THE COMPLEX HAS A hAMPTON bAY CEILING FAN WITH A REMOTE JUST LIKE US. wE MUST BE ON THE SAME FREQUENCY AND WHEN THEY TURN THEIRS ON IT WILL MAKE OURS COME ON WHEN WE HAVE...
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Feb 18, 2009 | Universal Remote Control Hampton Bay...
2 lg dvd players in same room,can I change remote frequency
I have new Panasonic DVD & Combo units stacked on top of each other and had the same problem, until last resort I read the manual and and easily changed the frequency on the DVD unit and remote, you can have up to 3 Panasonic units with different frequencys close to each other.
Dec 28, 2008 | Televison & Video
TV remote is turing on VCR
Is it a original remote or a replacement universal remote? If it is the latter, then it looks like someone has accidently programmed it for the frequency which is compatible with the recieve frequency of the Remote sensor of your VCR or DVD player.
May 09, 2007 | Daewoo DTQ-19V1FC 19" TV
Televison & Video Logo
59 people viewed this question
Computer Repairing
Computer Repairing
