Question about Dell E173FP 17" LCD Monitor
Dear, I have a monitor dell E173FP. The button (-) function always display on the screen. Would you tell me the reason and how to solve it. Thanks, From Roeurn Veasna
    Problem Solver:
  • 7 Answers
At the bottom of the monitor there are buttons, go ther and change the settings.
Posted on Mar 12, 2011
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
How do i turn off power save mode using the screen buttons
I don't know if there is a monitor with a function button to turn off the power save mode.
As far as I know the power save mode of the monitor can be found in the display setting of the windows..
Anyway... If you want to turn off the power save mode of the monitor via windows display setting then here is what you need to do:
On control panel, double click display settings.. click the screen saver tab... on the lower portion Press the "power" button.. Select power schemes tab.. Change the settings of" turn the monitor off" to "never"
Click apply and then OK..
Hope it gave you an idea..
Much appreciated if you rate this help...thanks..
Uncheck the box
May 19, 2010 | Dell E173FP 17" LCD Monitor
My monitor is brighter on the lower left side than on the rest of the display?
NOTE : steps below are only for a Dell monitor
There could be two reasons for the same,
1. The monitor settings are bad or
2. The monitor has gone bad.
Request you to disconnect the monitor signal cable from the back of the computer (cable with the blue jack)
A self test feature check would run on the screen. If the screen is bright in the feature check . The monitor has gone bad and needs a replacement.
If the screen appears ok in the self test . Press the menu button on the monitor and select factory reset.
Thanks
Proton
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
I need a Vista Driver for Dell E173FP. I can only find Windows 2k and XP drivers. Please Help!
You don't really need a driver, it's perfectly OK if it stays as "Plug and Play monitor". Monitors communicate with the graphics cards to inform about the modes in which they can operate.
All you have to do is find out the "native" or "recommended" screen resolution and refresh frequency for your monitor model and set these values in Windows' Display Properties - Settings.
In case of DELL E173FP it will be: resolution 1280x1024 and 60Hz refresh.
Nov 29, 2009 | Dell E173FP 17" LCD Monitor
My dell e173fp monitor has quit working. The power light continually blinks when power is applied, even without having to turn it on. An identical substitute monitor works fine on the computer system. ...
Is the power blinking amber? This is a DPMS power-save mode. With the computer disconnected and the monitor on, do you see the colored self-test block floating around? With the monitor on, computer connected, and you still have no image displayed, take a bright flashlight and examine the screen closely. If you can see a very dim display in the screen, the fluorescent tubes which light up the *background* and provide the vivid picture(sort of like a how an x-ray picture viewer works) are defective. The power light blinking may be the power supply sensing the non-functioning tubes or it could just be bad. If your display is under warranty, replace it. If not, trying to have the monitor repaired for this type of problem is almost as costly as a new one--and there won't be an active warranty on anything else that might fail. Hope I helped you.---Rick
Sep 10, 2009 | Dell E173FP 17" LCD Monitor
Has power but no display
Do the flashlight test. Shine flashlight on front of screen at angle and see if you can see an image or lettering. If so, it is probably inverter board. Let me know first if you have an image.
Jan 29, 2008 | Dell E173FP 17" LCD Monitor
hi, check out the micro switches on the monitor.. let me know..
Nov 17, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Nov 04, 2007 | Dell E173FP 17" LCD Monitor
White screen
First, always try it on multiple types of computers (different video cards), and multiple cables. Then, open it up and make sure the internal connections are solid. Finally, consider putting in a new inverter. This has been known to fix all-black and all-white monitor problems.
Dec 02, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Monitor Logo
Alun Cox
