Question about Acer Aspire 7520-5185 Laptop
Smart failure predicted on disk and cannot load Vista after format due to projected failure. Now it is happening again on a different HDD. Can both HDD's be ready to fail?
    Sergeant:
    Champion:
  • 269 Answers
It is entirely possible, but not terribly likely, to have two drives fail in a row. I have had several of my drives make it more than 6 years, and I've seen students come in with dead hard drives they day they bought their machines.
Posted on Mar 12, 2011
  • 1,940 Answers
Sometimes you can disable the SMART, or Self-Monitoring, Analysis, and Reporting Technology, but on your Acer Aspire 7520, you cannot disable SMART in your BIOS.
It is possible that you received a hard drive that was already faulty, or you may have bought a refurbished drive that had been previously repaired and is failing again. I recommend purchasing a New harddrive, not refurbished. When installing the new hard drive, be very careful to not subject the Hard Drive to any jerking, dropping, impact, etc. as this will shorten the life of your drive considerably, or worse.
Hard disk failure
Purchase a new hdd NOW! and copy your data off while it is still there. You may be lucky and be able to use CloneZilla to clone the failing hdd saving you hours of uploading drivers etc.
Feb 09, 2016 | Lenovo G550 Laptop
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
How to resolve problems (smart failure predicted on hard disk 0 : toshiba MQ01ABD050 - (S1))
Copy all the data from the drive to another drive because this one is predicted to fail very soon. Format the drive. That might work, but unlikely since SMART is a hardware problem and format is more of a software driven solution. It has some elements of a hardware issue, but not enough to fix most SMART problems. A low level format might help, but that is not a DIY.
Jul 12, 2014 | Computers & Internet
I received the following error on my HP Pavilion laptop: SMART Failure Predicted on Hard Disk 4: WDC WD2500BEVS-60UST0-(S1) Warning: Immediately back-up your data and replace your hard disk drive. A...
SMART is used to measure your HDD health.It warns you of impending failure of your hard drive. If it goes down, it's a good idea to backup important stuff and prepare to replace the HDD.
S.M.A.R.T is an acronym for Self-Monitoring, Analysis and Reporting Technology systems (SMART) and it's usually built in to most modern ATA and SCSI hard disks.
If you need further assistance, feel free to ask. If this answers or solves your issue, please rate it. Thanks, Joe
Feb 09, 2011 | HP Computers & Internet
Smart test failed on the drive
A smart failure warning is an internal hard disk drive self-diagnostic that will help predict a failure of the hard disk drive. Any system that is displaying a SMART error should immediately have any important data backed up as the drive is not reliable and is impending failure if it hasn't failed already.
Resolution is hard disk drive replacement, Generally around $100 depending on size and speed of replacement HDD
Jan 25, 2011 | HP Pavilion Slimline s3700y Desktop,...
Acer Aspire 5100: SMART Failure on Hard Disk 4
Hello there,
As per experience, SMART Utility will check your HDD for any errors that may occur.
I backed up everything and replaced a new HDD and got rid of the error.
Opened up the problematic HDD and noticed a very light scratch on its "platters".
As for me. Never ignore this warning before something might happen to your HDD and lost important data.
Mar 08, 2010 | Acer Aspire 5100 Notebook
SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Jul 29, 2009 | Computers & Internet
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Acer Aspire 7520-5185 Laptop Logo
497 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
