Question about M-Audio ProKeys Sono 61-Key Portable Digital Piano
Pitch automatically bends when i play even without me touching the pb wheel
  • M-Audio Master
  • 5,603 Answers
The resting (centering) of the PB wheel has a problem. It is LIKELY mechanical in nature. You will have to open the unit to investigate or take in for servicing. If you open it yourself, have two people to help hold the two parts of the shell to avoid damaging the ribbon cables when opening.
Posted on Mar 12, 2011
Numark ndx400
1 of yor tak switchs are faulty either cue or play button or maybe even the scratch button replace all 3 that should solve
Aug 03, 2013 | Music
Pitch bend issues
Hi, try to find how to reset it or go to default mode,find out in the users manual.Hope it will solve your problem,
Oct 17, 2017 | Akai Ewi4000s Electronic Wind Instrument
Got a Roland GW-8. I've had it for almost a year and a half. The problems consists on the fact that the keyboard gets out of tune while playing. Its not even a full note. After that I have to shut it...
OK... It is literally impossible for the unit to "go out of tune" as it is crytal controlled... HOWEVER what is probablly happening is the PITCH BENDER is getting into the mix somehow.
If the centering on the pitch bend control is sticking or is loose, this would likely be the problem.
Do some tests with the pitch bender to see if you can detect either a mechanical or offset condition of the control.
Mar 10, 2011 | Roland GW8 Keyboard Arranger
Yamaha wx5 out of tune (1 tone to low) and pitch bend wheel working up but not down...
As an electrical engineer, I suspect that one end of the resistance element or the voltage supplied to it is broken. This could be a broken circuit trace on a board or failure of the pitch wheel pot. This is iff the device has a center tapped pot. IF IT DOESN"T (schematics are hard to find on this) then the bias setting for the pitch wheel may be wrong. First thing would be to look if the the wheel has slipped on the control shaft.
Jan 03, 2011 | Yamaha WX5 Midi Wind Controller
My tyros 2 has fallen down very bad.now the left bass octave is off pitch(half note Higher) when i play the keybord with the accompaniaments.It works right ONLY when the ACMP is disambled what can i do....
Likely you have damaged the pitch bending wheel and offset it.
Try to pull it on pitch with the wheel... IF YOU CAN, then the alignment of the detent of the wheel has been disturbed and unit will need servicing... There are a lot of screws to open this and several very tender cables that can be damaged... I would recommend you take it to a shop experienced on this keyboard.
May 16, 2010 | Yamaha Full-Size Keyboard
When I play the sound come out distorted, like it untunes. any idea what is causing the problem? this is a for a Korg X50 and is only 2 yrs old. not korg Ma30
The manual is at:http://www.korguksupport.co.uk/upload/X50_OpGuide_E1.pdf if you don't have one. Try saving everything you want to save first if you know how to do that. Then initialize the keyboard. Follow the instructions on page 111 carefully. It sounds like you created an undesirable effect and accidently assigned the Pitch Bend Lock function to the effect. This parameter is explained on page 41 under Pitch Wheel Mod Wheel. Hope this helps.
Aug 19, 2009 | Korg Ma30
I would like to change the pitch bend range in style edit mode- for example i would like to have it bend 12 notes rather than just 2. please help and thanks!
Hello :) I can help you :) First of all,press menu button.Then,on the screen touch MIXER TUNING.Then at the bottom of the screen press TUNING,and you'll find PB sensitivity.And then touch the number one the screen,which appears under PB sensitivity.At the end,just scroll tempo/value dial from 2 to 12 :) That's simple :)
Apr 22, 2009 | Korg Pa800 Synthesizer
Detuning of Akai EWI 4000s
Are you shure that you aren't touching the bend up plate with your right thumb? This isn't easy detected by sax players which are used to have a thumb rest at exactly the same spot where the bend up plate is. You might switch it off (see manual). With the bend up plate on you should aways use a tight strap which helps a bit to not touch the bend up plate accidentally. I'm still struggling with this occasionally.
Oct 31, 2008 | Akai Ewi4000s Electronic Wind Instrument
YamahaDGX-220 YPG-225
Do a factory reset. First try pressing the + and - buttons simultaneously.
Look in your user manual for a complete factory reset and do that.
Aug 02, 2008 | Yamaha Full-Size Keyboard
M-Audio ProKeys Sono 61-Key Portable Digital Piano Logo
184 people viewed this question
Top M-Audio Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
rhodesworks
Are you a M-Audio Music Expert? Answer questions, earn points and help others
