Question about Maytag 22.7 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black
Refrierater stooped producing ice cubes and water is leaking plus water is not coming out cold
  • 219 Answers
SOURCE: stopped giving cold water, then stopped producing ice
replace the watervalve
Posted on Mar 19, 2009
tborn6
  • 700 Answers
SOURCE: Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
Posted on Apr 03, 2009
  • 351 Answers
SOURCE: ice maker leaks and causes the ice cubes to freeze
sounds like the water valve gets stuck open go to whirlpoolpartssurplus.com and call me i can get you a really good price.
Posted on Jun 23, 2009
SOURCE: It produces cold water but no ice. The augar works
you may want to check the pump in this refrigerator, that could be one of your problem.
Posted on Nov 13, 2009
Sea Breeze
  • 4654 Answers
SOURCE: MAYTAG ZIG-ZAG FRIDGE-FREEZER WANT DISPENSE WATER
Sounds tome that there is a short in the dispenser control circuit, keyboard or Control Board. If you had the model number I could help you better than this. I possibly would be able to walk you through this, Let me know, Sea Breeze
Posted on Nov 19, 2009
My Crosley Conservator Ice maker will only produce crushed ice, HELP!
Ensure the Wire Signal Arm is not in UP position. • Ice maker should produce 2.5 to 3 pounds of ice in a 24 hour period. • Water supply is turned off. • Water pressure is too low. • The freezer is not cold enough.
Apr 15, 2015 | Crosley Refrigerators
My ice maker has stopped producing ice - I have a whrlpool fridge freezer
Causes are:
1. Check shut off arm- If it fails to move due to lot stored ice cubs, remove some quantity of ice cubs.
2. Check the water pressure. Due to lack of water, it may stopped producing ice.
3.Check freezer temp: must be around 5 degree.
4.Check water hose has no leak. due to scarcity of water, ice maker could stop making ice cubes.
5. If water valve defective ice cube could not be made. To check the valve please follow this step.
Locate your ice maker, remove the ice bucket. Pull the coveroff the end of the ice maker. Locate the holes "V" and "L". Take a paper clip(jump clip) and tape. Straight the clip and put tape in middle. Hold the tapedside and insert the clip into "V" and "L". This sends the power to watervalve.If water goes into ice maker, water valve is good.Hope, is it helpful?
Jan 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My maytag stooped cooling and does not sound like it is running
Normally we have seen two issues.In one instance the water feed tube or trough stooped the flow of water to the ice maker and this produce a small transient water leak initially and then it stopped working and leaking eventually as the blocked tube did not thaw.
The other issue was ice in the ice maker that lodged in the blades of the ejector and prevented ice production.
Thanks for contacting Fixya.
Nov 03, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
The freezer door was ajar overnight and now the icemaker is leaking water
chances are alot of the ice melted overnight. remove all of the ice cubes, dry everything out and then wait a full 24 hours for the icemaker to produce ice cubes.
Aug 28, 2009 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice maker stopped making ice
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | LG LFX25960ST Stainless Steel French Door...
Water is leaking out of ice maker and freezing up where cubes are
Sounds like water valve is not closing all the way after the icemaker calls for water. This is because sediment in water builds up on valve seat therefore letting water pass through. Suggest replacing fill valve. Crescent shaped ice....ice maker on needs 4 ounces to fill icemaker, so any more than that will spill out.
Jul 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
Have an LG LFX25960TT refrigerator with in door ice maker. The ice maker only makes 2 to 3 ice cubes at a time. (Too slow for my family's needs.) It appears like it doesn't get enough time to fill. Is...
Check to make sure the water supply to the refrig is good and the inlet screen where the water line connects to the refrig is clean. You can change the amount of water fill by pressing the button on the left side of the ice maker. (indicator lights above button show setting) Selecting "Ice Plus" on front of dispenser panel increases ice production for a 24 hour period. Ice maker should produce 6 cubes per cycle, aprox.. 100 to 130 cubes in 24 hours depending on freezer compartment temp, room temp, number of door openings, etc.
Sep 10, 2008 | LG Refrigerators
Maytag 22.7 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
