Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
  • 2,019 Answers
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Posted on Mar 12, 2011
  • thompsontwel Apr 20, 2011
    Video link worth a thousand words.
My ***** 450rancher doesnt seem to be getting bar oil to the bar any sugg.
yes it can become plugged but what concerns me is that you said you just changed your bar. If you didn't get the right bar the oil holes will not line up thus no oil getting thru or you may have an adjustable oiler that's not set properly
Nov 04, 2014 | Garden
My husqvarna automatic chain oiler doesn,t work...235 husqvarna any fixes?.
You may have gotten some saw dust particles inside the oil resevoir that got sucked into the delivery tube, thus clogging up the oiler...you can drain the oil out of resevoir and run some seafoam thru the oil resevoir to see if you can get it unclogged
Jan 23, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My automatic oiler is not releasing any oil
With the chain & bar removed the oil should be cleary seen if run.common fault is sawdust getting into the oil chamber.
Nov 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw Bar Chain Oiler Stopped Flowing
The filter can usually be caught with a hooked wire and drawn up far enough to deal with the filter. Oil filters are not prone to plugging unless the oil used is contaminated. If you run the engine without the bar and chain attached, oil should ooze out of the engine side port. If nothing, suspect problems with the oil pump. Some saws use a plastic gear in the pump and can strip the teeth of the gear. You should find it located behind the clutch assembly. Once you have oil flowing from the engine, clean the bar drive-end oil ports that go from the large holes out to the chain groove on each side. Finally, run the bar tip near some cardboard--it should throw off a thin line of oil. I have no idea what the plastic tube might be (a manual pumper perhaps?). Hope this helps!
May 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Automatic Oiler is not working on my Husquvarna 45
This usually means the oiler hole behind the bar & chain is plugged. you need to remove the bar & chain, clean the body of the chain saw in front of the sprocket/clutch assembly. look for a small hole & clean out using something like a toothpick & wd40 or penetrating oil.
Nov 15, 2009 | Husqvarna Chain Saw 20" Bar
It seems like the chain is not getting any oil earlier in the day the saw was fine. I had to replace the chain and started sawing on a tree and the chain just smoking and burning the wood. It does not look...
Are you using any oil in the oil resivour? The oil lubricates the chain on the bar. I would guess that you installed the chain backwards. If the chain moves freely on the bar it is getting lubrication. I have made that mistake before. check rotation and your new chain. Don't know what brand of chain saw you have, automatic oiler, manual oiler, ect. but would guess that the problem is with the chain itself. Hope it as simple as that.
Aug 23, 2009 | Poulan Garden
Husqvarna 141 will not oil and when i had it serviced they replaced the oiler and it did not solve the problem.
Remove the chain and bar assembly. Start engine--should pump oil from oiler port where the bar fits on the engine side. If oil comes out, then possibly the bar-oiling passage in the bar itself is plugged with dirt or sawdust--blow clean with compressed air. If no oil comes out from the port, check the pickup tube inside the oil tank. Drain the oil into something and fish the pickup tube end out with a hooked wire. Replace if collapsed, cracked, or loose.
Jul 04, 2009 | Husqvarna Chain Saw 20" Bar
Chainsaw oiler leaks oil out case and no oil on chain
Take the bar and chain off--run the engine--the oiler port from the case should discharge some oil. If none, you have trouble with the oil pump or the tubes to and from it. The oil tank may be leaking at the tank opening for the pickup tube. If oil appears at the oiler port, then there may be dirt/blockage within the oil passages in the bar end. Clean with compressed air.
Jun 28, 2009 | Garden
Trouble with Poulan 2150 Chain saw automatic chain oiler
Hi
It is gear driven oiler and there is not any adjusment for it.
regards savumihai71
Dec 11, 2008 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
1,026 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
