Hi, our Zinwell ZMT-640PVR remote control does not work properly. One button after an other stops working. Today I got a ONE4ALL URC7555 R00 universal remote. It worked fine to pick up the TV but the Freeview box codes for Zinwell both did not work. Can you help and tell me the right code to use? Need help. Please. Kristina
SOURCE: Using my universal remote to control my iLo 27" Wide-Screen LCD TV
I have a ILO 27" TV Comcast had no suggestions for programming their remote. I went thru the ENTIRE code book and finally came up with one that worked: Emerson Code #0463 for my COMCAST universal remote.
Posted on Aug 10, 2007
SOURCE: Element LCD TV FLX-3210
Try 004. That worked for me
Posted on Jan 02, 2008
SOURCE: Remote Codes
i lost the codes of my remote and now it's malfunctioning.. the brand is CHUNGHOP RM-88E..the Brand of my tv is Goldstar.. can you help me with this or can you just give the codes?
Posted on May 19, 2008
  • 3 Answers
SOURCE: POLAROID 1511-TLXB LCD TV Remote Code for Verizon FiOS STB
I posted that as a point of information. I noted from searches that other people were having remote code problems w/that TV set. Code 0205 worked for me.
Posted on Aug 25, 2008
SOURCE: Remote control code needed
i have a connect- it bd512 universal remote control i need a code to programme in to my tv it is a baier please help!!!!!!!!!!
Posted on Mar 03, 2009
Red light stay on tv on no picture
try replacing the batteries in the remote control.
maybe the remote control has stopped working, you might want to get an aftermarket remote such as a one4all.
May 26, 2015 | Televison & Video
I don't have a remote to my zinwell zat 970a I
you can download from www. remotecodelist.com and fix it. or
www.directv.com
God bless you
Jul 08, 2013 | Televison & Video
I bought this control and threw out the manual I didn't realize I needed one it's model no: URC 11-2981 R00 Anyone know how I can use it
Hi Please check the have you inserted 2 battaries (AAA
(x2)).
Search method:
1) Press TV button.
2) Press Magic button and hold for 3 secs
3) Now press 991
4) now press power button
5) now press CH+ button until your television turns off. This may need to press many times.
6) Once turns off, press magic button.
7) Now press Power button. some times TV may not turn on, at that time press any other button.
Volume Lock:
1) Press magic button and hold for 3 seconds
2) press 993
3) press TV Key.
If you require more option please post which option require to you.
Feb 10, 2013 | Televison & Video
What is the 'One4All' remote code for Celcus TVs?
Try these codes. If it do not help you, Try code search method.
0147 0135 0250 0257 0310 0394
Code Search Method
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 05, 2012 | Harley Davidson XL 1200 C Sportster Custom...
Zinwell zmt-620hd "no signal" The signal is good -
This isn't a solution, I'm afraid, but I believe I have the same problem. My Zinwell ZMT-620HD has failed more gradually. It used to work sometimes, and I thought the aerial was the problem, but even on a good aerial it cannot detect any channels.
Maybe this brand is (expensive) ****?
Feb 12, 2011 | Televison & Video
I need a code to progam this remote to control a zinwell zat857 dtv converter box! please
OK, I have a Zinwell box that was working perfectly until a friend tried it in his new apartment. Two problems (a) he misplaced the remote over there, and (b) he reprogrammed it so it now only gets four crappy channels instead of the previous fifteen.
Will try to get him to search for remote. Meanwhile ar 4am:
I have two universal remotes, old Magnavox and newish Ptimesat. Primesat looks good but doesn't seem to have search fubction -- does it> Tried to get Zinwell to work on Aux wth code 591 but no luck, Search on Magnavox got one partial result but failed again. Help?
(b) Is there any way to reprogram the box manually, without a remote? I want my channels!
Nov 14, 2010 | GE RM24948 Remote Control
One4all-6131 remote and apex digital adv-3800
none of the published codes for one4all work for a mintek tv&dvd/video/player let me know plss at bigbadtaz06@aol.com
Jan 23, 2009 | One For All URC-6131 Remote Control
Need new remote control
The best and cheapest option would be to buy an all4one remote these operate everything from tv to dvd to sky ,cable ,stereo etc you can buy these for next to nothing from any major super market or diy store these can be programmed to work just about anything and cost next to nothing. Buying an original can cost ten times as much as one4all remote "one4all" is about the best make of multi remotes and this make usually works on any type of dvd or tv so give it a try it will save you loads of money.
Also a good thing to have incase another remote stops working so it would save you buying another remote again
Apr 25, 2008 | Televison & Video
Televison & Video Logo
198 people viewed this question
Top Televison & Video Experts
