Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Wet dishes; steam does not escape
My dish washer does not vent the steam. The dishes are very wet unless I open the door the last few minutes of drying and let the steam escape. Could a steam vent be covered from shipping? Where is the vent?
  • 2 more comments
  • Lavin Jan 14, 2009
    The rise aid did the trick. Thanks for helping me figure that out. No more wet dishes! Thanks again,
  • inetta Jan 23, 2009
    I also have this same dishwasher. I have had 7 repair men out to try and fix this problem.The inside of the dishwasher remains wet resulting in spotting on the dishes and making the inside of the dishwasher disgusting plus there is a terrible odor when you open the door!
    It seems that every repair man has a different opinon regarding the jet-dry or detergent used. The jet-dry dispenser is always full (repair men each take a turn at turning it up or down).
    Today I called Jenn-Air and they told me that it was not drying because the dishwasher was on an exterior wall and the hot water tank was to far from the dishwasher resulting in the water temperature not being 120 degrees when it reaches the dishwasher......
    I bought this dishwasher from Sears contract sales and have had no help in resolving the issue from them.
    Can anyone HELP!!!
  • jvatter Mar 01, 2009
    We have had the same problem for three years! We use rinse aid, we tried adjusting the water heater temperature to very hot which should put the water around 140 degrees when it reaches the dishwasher. Still no improvement.
    We have another house with an inexpensive whirlpool dishwasher which makes this one look like a piece! It cleans great, is just as quiet, the trays are very functional unlike the jenn air, and dishes are always dry as a bone and spot free after the cycle is finished. It has a vent in the front which allows the steam to escape. How are dishes going to get dry if the steam (water) is not allowed to escape the unit???
    No one has been able to help including the dealer, installers, jenn air, etc. Are you sure there is not supposed to be a vent somewhere?
  • Kris Seymour May 11, 2010
    Do you have a rinse aid in it? As low or no rinse aid will cause the items to be very wet! The steam inside the d/washer is there for it to dry! So opening the door is really defeating the object!
    Scholar:
  • 86 Answers
Hi, Most dishwashers do not have steam vents! there are several reasons for poor drying in a d/washer! The first one is to see that you have rinse aid in the machine as this aids drying! Next if you have rinse aid then is it being put into the machine when it needs it? Also you must bear in mind that the dishwasher need to heat on the last rinse to create the heat to dry the items which use the steam to dry them. Check the rinse aid first and see how you get on....
Let me know.......
Posted on Dec 30, 2008
  • Kris Seymour Dec 30, 2008
    Hi check the rinse aid is full and working. All dishwahers rely on steam to dry the dishes and they use rinse aid to let the water drip off them to dry. Thats why you get streaky glasses when the salt or rinse aid is low...
Dishwasher washes dishes but does not dry even though that display shows dry icon
First ,Check for a water puddle on the bottom of the dishwasher .If you have water there, you more than likely have a plugged drain or drain hose, or bad drain pump (less likely) If no water is there see if the dishes are hot after a cycle. If they are not you could have a bad heater (that circular thing on the bottom of the dishwasher) other problems could be the timer or computer Depending on the model brand and age of the dishwasher .One last thing there is a vent to let moisture escape that could be bad but then you would have hot wet dishes
Aug 07, 2014 | Blomberg Dishwashers
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
Dishwashere not drying
The vent is in the door and you need to remove the panel on the door. However, if you take the kick panel off the bottom, there should be a techincians guide attached to it and that shows all the tests etc that you can use to troubleshoot this.
Nov 18, 2013 | Frigidaire PLD4555RFC Dishwasher
The dishwasher dose not get hot at all and when it has finished washing every thing is still wet
  • Well, the dishes inside the dishwasher will still be wet unless you use a dry cycle at the end of the washing cycle. Not all dishwashers have this option. Even though mine does I rarely use it as the dishes will dry on their own in two hours.Saves a little money. Even when washing on a normal cycle the dishwasher itself should not get hot. It may blow a little steam out the front vent. Hope this helps.
Regards, Tony
Jun 08, 2011 | Dishwashers
Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards, BElectric
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
Jan 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Constant Failure
Problem #1 solution.  Make sure that you are using a rinse aid.  All dishwashers require a rinse aid to assist in drying the dishes.
Problem #2 and #3 suggestion.  Possible that the door is either warped or not closing properly.  Make sure that the cabinetry is not obstructing the door from closing properly.  Another possibility is if the side mounting holes are used to screw the top half of the dishwasher to the cabinetry, they may be screwed so tightly that they are pulling the frame of the dishwasher away from the door causing the steam to leak out the sides.  Recommend loosening the screws slightly to allow the dishwasher frame to return to it's normal position.  Hopefully, the frame hasn't deformed.
Problem #4 solution.  You may need to replace the sump assembly as the wash motor may have a problem pump enough pressure to wash the dishes properly. The sump assembly comes as one with the drain pump included in it.
Apr 23, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
1,253 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
