Question about D-Link DIR-615 Wireless Router
We are no longer getting wireless internet from the router. I try to follow the directions on the bottom of the router, but I have not even found where to type the word"admin." Please help if you can. thanks
    Sergeant:
    Champion:
  • 269 Answers
On the back of your router there will be 5 ethernet ports. At least one will contain a wire going to your router. Unplug this wire, and plug it into one of the remaining 4 ports, doesn't matter which.
Now unplug the other end of the wire from your router, to your computer. Turn the wireless off on your computer, and go to http://192.168.1.1. It will prompt you to enter in the admin password here.
If this does not work, unplug the router and hold the "Reset" button on the back with a pencil for 30 seconds.
Posted on Mar 12, 2011
Slow internet speed when connected to router
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Jan 26, 2013 | Linksys WRT54G2 Wireless Router
I try to plug in my belkin 54 wireless usb thing into my xbox 360 and my xbox doesnt even recognize that it is in there and i dont know where to start but i would like to be able to play games online and...
XBOX 360 is alredy wifi enabled you dont have to plug a thing in to it, if you want to configure wireless
All you got to do is turn on your wireless router/access point and try to search for available network in Xbox 360 and upon selectin the network it would ask for wireless key (WEP key cab found on the back or bottom of router) punch in the key and bingo...its done
Your box is ready to be wirelessly connected to internet and play online
alternatively if you dont ahve a wirelss router or you are facing difficulty is seraching wireless router or finding the security key
Connect the router to modem > then connect the router and XBOX with an ethernet cable
It will work
Else you can also try connecting the modem and XBOX with an ethernet or USB cable
(However in all the aboove scenario, please ensure the modem is getting the internet link through the normal RJ11 or phone cable, please dont unplug that else though your XBOX would be connected to Modem or router but it wont get internet connection)
Aug 01, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Im only recieving 1020 speed download, when should be atlwast 8
First, if you are connecting to the router with wireless, there are a couple of possible problems. If you are using Wireless B, you'll probably only get around 4 or 5 mbps at best, and even with wireless G, if you happen to have your router set to the same channel as your neighbor or several of your neighbors, it will slow down a LOT and could even have trouble staying connected. To check this, try plugging directly into your router and disabling the wireless on your computer temporarily and run this test again. If it is much better, try changing your wireless channel.
Second, I'm not familiar with this particular model of router, but I've found that many of the cheaper and/or older routers cannot handle the current speeds we see on cable and DSL connections. This could also be a problem with your cable or DSL connection. To check this, you can temporarily bypass your router and plug your modem directly into your computer. Remember this exposes your computer directly to the internet, so it's probably not a good idea to leave it that way. You may also have to reboot your modem and even reconfigure it and your computer to do this depending on your ISP. If it is still slow, you will need to contact your ISP and complain!
Mar 09, 2010 | Belkin (F5D7231-4) Wireless Router
Cannot connect to internet with konaki netbook
How to Connect a Laptop to a Wireless Router Using a Windows Operating System
Follow the router's manual to set up the router and its Internet connection , which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
Click on "Properties."
Select the "Wireless Networks" tab.
Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
Click on "Configure" when you see your network's SSID in the "Available Networks."
Enter your network's SSID and WEP key.
Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Dec 12, 2009 | Computers & Internet
Linksys Wireless WRT54G Router Won't Connect
Here's something you can do.
First, power off the modem and the linksys.  Then swap the yellow cable with the blue cable (this time, connect yellow cable to port 2 of Linksys)
Now, turn on the Modem first... wait about 1 minute, then turn on the Linksys.
1. Log into the router and go to "Status" tab.
2. You should see something called Internet and under it Configuration type.  If all you see is 0.0.0.0 without a gateway address, it didn't work
3. You can also see 2 buttons at the bottom of the screen.  Click on "DHCP Release", then "DHCP renew"
4. look at the configuration type and see if it is no longer 0.0.0.0 Then try connecting to the internet to a website you have not visited (do not try the same websites as before when you initially tested).
Jun 29, 2009 | Linksys Wireless-G Broadband Router
I cant play online without the modem being by my ps3?
Yes, using a longer ethernet cord will work, but the PS3 has a bult-in WiFi card that can connect to any wireless router (you can buy a wireless router from a computer store like BestBuy).
If you are going to buy a wireless router, see if a wireless G-mimo or wireless N with signal boost is within your budget. Try looking through the network settings to see if you can connect through the wireless router.
Or just get a longer ethernet cord and run it directly to the PS3 from the router. Ethernet cords are the most reliable connection, granted you are on a good internet connection, they won't get interference from things like mobile phones, cordless phones, microwaves, TV's etc.
I have both the PS3 and Xbox 360 and the only thing I like better about the PS3 is the free online game play and Blue-Ray. Other than that, they're even. Good luck and have fun online! If you find me (wraith0127) say hi! Don't forget to rate. Thank you!
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Netgear WGT624 router won't connect to the internet
I am in the UK and have found through experience the Netgear's seem to work perfect on a BT line (equivalent of AT & T)
but not on the cable.
I would suggest purchasing a Linksys by Cisco WRT54GL Wireless-G Broadband Router as these seem to install in minutes,
saves me hours of wasted time when setting up wireless networks.
Jan 18, 2009 | NetGear WGT624 Wireless Router
Router
check you cable connections, try to check if you can go online wired to the router if you are connecting wirelessly. You can also bypass the router and connect directly to the modem to make sure its working.
Jun 15, 2008 | Belkin (F5D7230-4) Router (587009)
Linksys wireless problem
hiya krazy327... sorry to hear about your prob.. we,ve all been here at some point!
Can you let me know if it is one specific computer that the problem is with?
If so .. how are you wired to the router "True" wireless or usb/ethernet gateway from the router?
Regards Faggly
Mar 18, 2008 | Linksys Wireless-G Broadband Router
D-Link DIR-615 Wireless Router Logo
13 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
