Question about Sony Playstation 3 (PS3) Console
My screen appeared a red screen,why? and how to solve that?
Did your screen also show a message, in many different languages?
I have had this happen to me a few times while watching movies. Restarting the Playstation seems to correct the issue. I do not know the direct cause.
Posted on Mar 24, 2011
My son's playstation 3 has power going to it, the hdmi is new. The disc appears to be moving in the ps3 but nothing is appearing on the screen. All connectors are in correctly.
That happens when you change tv.
Unlpug it and wait for 30 seconds.
Plug it back. The red red light that indicates that the ps3 is off should be on.
The light must be red(turned off)
Now do this:
PRESS and HOLD the power button for 5-6 seconds untill you hear the second beep
There you go
check here if this didn't work
http://www.portfolioofpb.com/blog/update-ps3-blank-screen-switch-inputs-hdmi-to-composite-to-hdmi
Please rate if this solved your problem
Apr 15, 2011 | Video Game Consoles & Games
Dear Experts! My laptop (VGN FW30B sony) has the display problem, there is a red display on the screen. The red colour is very annoying me. Some technician said some Wire is broken, if we change the...
The display panel appears to be your problem but i would replace the video inverter too when you replace it.Replacing just the display panel should do the trick though.
Jan 26, 2011 | Computers & Internet
I have a red reflection on my screen. I heard it called convergence. How do fix it? It is 4300 series
Go into your main menu and scroll down to picture. Next scroll down to convergence press select. A white cross should appear on your screen the object is to converge all the crosses into one untill all the crosses appear as one white cross. The onscreen directions will tell you exactly how to do this. Next press continue and several little white crosses will appear across your screen. Do the same for each one of these white crosses. This should solve your problem.
Aug 14, 2010 | Apex Digital GB4308 43" Rear Projection...
The screen is blank white and the back light keeps flashing
Sounds like your charger isn't working. Meter it. Also possible, it may nt be working IN the phone.
Aug 08, 2009 | Palm Treo 680 Smartphone
Red screen appered
1) run into the bathroom and cry:-( 2) Bring it back to where you bought it, and they have to solve the problem, its law that products must be of saleable quality, clearly yours was faulty.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Screen problem
loose connection or cold solder of your neck board in the crt socket need to re soldering by using soldering iron.
Jan 11, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Red bar across top of screen??
I had the same horizontal, solid red bar along the top of the tv screen. I have an older analog Philips Magnavox TP2785C221. It just started all of a sudden. It was on every channel. However, the bar did not appear on the other input channels (e.g., AV1, AV2). So this meant that the red bar was only occurring on the antenna input. I unplugged my cable decoder box and restarted it. The red bar went away and that seemed to solve the problem for now.
Jun 25, 2008 | Philips Magnavox 42MF521D/37 Television
Pdal OS ianvalid image error
this pblm can be solved by resetting d mobile in master clear option. after resetting power off d mobile and on after 5 min,and connect to the net upgrade ur os, b4 upgrading remove memory stick and upgrade , this will be solved....
Jan 19, 2008 | i-mate PDAL Pocket PC
Sony Playstation 3 (PS3) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
